I'm trying to record voice only from my IC-R75 receiver to a macbook pro laptop.It needs to be lined in with leads.What program and leads would i need?
Unfortunately, *IF* my son's `school supplied' Macbook Pro is any indication, you may be `SOL' as it doesn't have a line in input. *If* yours does it'll probably be a 1/8" Stereo input. The IC-R75's REC OUT is a 1/8" Mono necessitating the use, if it is going to be hooked up to a Monaural recorder, of a cable of suitable length w/ 1/8" mono plugs on both ends. If the recorder is a Stereo recorder you are going to either us a Mono cable and an adapter that has a Mono jack and a Stereo plug. (Whenever I record from my R75 I usually just use my `normal' recording cabling which consists of a Stereo cable w/ 1/8" plugs on both ends and an 1/8" Stereo Jack to Mono 1/8" Plug. [The reason *I* use the Stereo cable is that I mostly record from scanners and I am recording SO/PD and FD from 2 separate scanners w/ one on one Stereo channel and the other on the other Stereo channel using an `Airline dual 1/8" Mono plus-to-1/8" Stereo Headphone jack "Y" adapter to connect to the scanners. I figure that if I have to record from a Mono source a Stereo jack to Mono plug adapter is a lot cheaper than buying another cable.])
SWMBO's chuckling about the preceding and reminding me that I already have *more than enough* assorted cables, while pointing to the *3* 6' long cable racks worth on the wall along with several `parts drawers' with all sorts of adapters, and *why* am I worrying about having to buy any more. I basically have all those because they are `leftovers' / `spares' from the Hi-Fi / Stereo Repair shop we used to run full time. {GRIN!} Anyway... While I may have all sorts of cables and adapters I figure that most people don't and would want to get whatever they are trying to done and not end up spending more than they have to spend so I try to come up with something that doesn't cost the proverbial `an arm-and-a leg' to
get it done.
Now the REC Control jack on the back of the R-75 only needs a suitable length 1/8" mono plug to plug cable if you were going to be using some sort of recorder that had the appropriate `mating' jack. While you *might* be able to find a cable that has both cables molded together it's quite likely that you'll pay more for that than the 2 cables, and associated adapters. (And probably get more use out of the separate cables and adapters.)
As for what program you need to use, if your laptop doesn't already have a simple sound recording program and you have to get one I'd look for one that can handle a stereo input, allows editing, and has a fairly wide selection of `formats' (mp3, wma or whatever, Etc. [I'll readily admit that I am only used to MS stuff as *I* only have pretty much used MS OSed machines, though I did also have a couple CP/M machines, too, and the only Apple product I had was an Apple IIe+ that I used to run my first BBS on many many years ago.])
Now... After all I've said, so far... Why not just pick up a decent Digital Recorder along the lines of a Sangean DAR-101? You can then record to up to 32G SD `cards' in Stereo using either `timed' recording control, `sound activated' control, `switched' control, or manual/free running control. The only `problem' I can even come up with is that instead of using 12VDC for it's external power it uses 9VAC. For battery power it uses 4 AAs which can be either `disposables' or `rechargeables'. (I don't know just what the battery life is with either. But, based upon initial `quick tests' one can probably expect it to go through the `disposables' in around 8 - 10 hours or so and the `rechargeables' in 10 - 12 hours, or more if using the high MAH versions, using the VAR recording feature.) From what I have heard so far the sound quality is quite good to excellent. If you have a SD `card' reader and editing software for your computer you can edit it about any way you might want and only be tying up the computer for what time it takes for you to do said editing instead of recording and editing with just the computer.
Just an `Olde Fart's' 2¢ worth. YMMV {VB GRIN!}
