Quote from Icom on their IC-R8600 ...
The high-resolution real-time spectrum scope provides class-leading performance in resolution, maximum 30 frames per second* fast sweep speed, ±2.5 MHz wide scope span (display range) and 110 dB of dynamic range (at ±2.5 kHz span). The waterfall screen allows you to find weak signals by showing the spectrum change over time. When tapping the spectrum scope or waterfall screen, the tapped area can be selected as the operating frequency. The peak search function finds several peak frequencies within the scope range, and helps you to select these.
Questions ...
How does the IC-R8600's real-time spectrum scope compare with the spectrum scope of the RSP2 using the SDRuno software?
What is the performance of the IC-R8600 on the HF frequency range (zero - 30MHz) compared to the RSP2?
Questions ...
