The State of Ohio maintains 800 MHz conventional analog repeaters on both 8ICALL (866.0125 MHz) and 8ITAC1 (866.5125 MHz) at select locations. See the following call sign and map that includes the two sites in our area:
http://www.radioreference.com/apps/db/?cs=WPQF736
Both the Toledo and Castalia tower sites would provide coverage for Ottawa County users. The Ohio State Highway Patrol maintains a listening watch on these repeaters and can be raised on those channels.
All Lucas County users have access to both the repeater mode and simplex talk around for all five 800 MHz interoperability channels. This is the same for State of Ohio MARCS users, and hopefully they've added all the repeater and talk around channels for Ottawa County.
Usually these channels would not be used or needed unless a specific incident would call for direct interoperability. Generally a command/admin or dispatch unit would be responsible to steer users to a specific channel as needed. So for example for an incident at Davis Besse, command units from Ottawa County, Lucas County, State of Ohio could all switch radios to a particular repeater (8ICALL, 8ITAC1) and any simplex channel to facilitate communications.
Also both Toledo Life Flight and ProMedica Air helicopters are supposed to be getting radios (and/or getting their existing programming updated) to have access to the 800 MHz interoperability channels. A pair of the simplex talk around channels have been generally accepted for use as "Air Med 1" and "Air Med 2" (I think it's 8ITAC3TA and 8ITAC4TA) for use with Landing Zones.
Also, if you're needed to provide some form of support or assistance for an area outside of the range of your normal system, chances are that other folks may have access to these channels as well. I believe the state has mobile equipment than can deploy additional repeaters to specific areas if needed. The state's mobile communications unit actually has the capability of providing a stand alone digital voice MARCS trunking site as well.
Our Lucas County emergency communications trailer has an old 800 MHz analog repeater on board. We need to look into the feasibility to see if it can be reprogrammed to provide the possibility of an additional 8ITAC repeater pair.
Here are some additional notes from the MARCS Statewide Interoperability procedure regarding the simplex talk around channels:
· 8ICALLTA, 8ITAC1TA through 8ITAC4TA.
These are the five National Public Safety Analog Talk-Around Frequencies. All five of these talkgroups are available for local, off the system, analog “walkie-talkie” communications. (Due to being analog, static may be noticed. Range is three miles or less, depending on terrain. Allows MARCS radio users to talk to ANY 800 radio programmed with these talkgroups.)
So I would say for the sake of testing, pick up the microphone and call for the Ohio State Highway Patrol on 8ICALL for a radio check . . .
