Icecast Issue
Burlington, WI
Not sure why my Icecast is constantly crashing lately. It started about 2 weeks ago. Here is the log from the system. Any ideas?
Faulting application oddcastv3standalone.exe, version 0.0.0.0, faulting module lame_enc.dll, version 0.0.0.0, fault address 0x00024b27.
woody_46
Canada, Eh!
I use Shoutcast for my radio station , if you're not using Lame for encoding try deleting that driver from the program files, it's likely corrupt. If still no go try finding a new Lame encoder to replace it. Sometimes just installing new software can cause conflicts between drivers.
You should also check any support forums for Icecast/oddcast. Somebody else may be having the same issues.
Hope that helps
Burlington, WI
Can't really find anything on it as the program is years old and not supported much. I'm afraid if I can't fix this I may end up pulling the feed. Nothing has changed at all on the machine. I don't even use that PC. Most of my work is done on my business laptop. I tried the lame_dll v4.0 and it's still crashing randomly.
Deziel0495
If your just using Oddcast to send your feed to RadioReference, maybe you should try switching broadcasters. ScannerCast is a great program made specifically for this. It's great! You may want to try it out! Hope this helps! :)
mitbr
Tampa Bay Florida
Try this program might fix your problem let me know if it does......the error your getting is a common registry error visit this web site and use the free app ..
How to Fix Standalone.exe - Fix PC Errors
Tim
Burlington, WI
It's not a registry issue. It seems pretty weird. If I run the program without minimizing it to the clock it runs and never crashes. However as soon as I minimize it to the clock the program will crash.
