Scanner Tales: Ladders
When you talk to some ham radio operators and mention the word “ladder” many will think about Ladder Line. This is that flat, two-conductor cable often used in ham radio antennas. The 300-ohm version used to be popular for TV antennas until pretty much replaced by 75-ohm coaxial cable. Ladder Line is used for balanced antennas, like dipoles, where both sides are the same. On balanced antennas a small transformer called a “Balun” is often used to allow coax to be used to connect the antenna to a radio, tuner or amplifier. (“Balun” is a compound work mixing “Balanced” and “Unbalanced”.)
For most people however “ladder” is that tool used to reach high places. As a former firefighter I was very familiar with ground ladders as well as the Aerial Ladder we had on the fire department. My main assignment was on the Ladder, I was a tall, skinny young guy who didn’t mind being strapped 100 feet up and getting hit by back-spray and smoke. One really cold January night we had a barn fire, and I spent a couple hours up there pouring water on the fire. With the wind shifting around I was soaked and got frozen to the ladder, caked with ice. The engineer lowered the ladder with me on it, and I rode back to the station there, and they chipped me out of there in the warmth of a heated equipment bay. A few cups of hot chocolate and a change of clothes later I was fine.
But for the purposes of our story today we will talk about the various ground ladders I have around the house to work on my antennas and radios.
When I bought the house the couple before us had 4 ladders here. 2 were painter’s ladders, probably more often used for installing Christmas decorations or changing bulbs in the ceiling lights. One was a light-duty aluminum extension ladder and the last was a larger step ladder that was probably used to clean his RV.
I kept one of the painter’s ladders and the extension ladder, selling the others at a garage sale. The painter’s ladder is perfect for household use. The extension ladder is perfectly sized for accessing my attic. I suspect however that the prior owner of my house used it for his Christmas decorations. We bought the house furnished and they had tons of lights, 3 Christmas trees and boxes full of decorations. As far as I could tell he was not a guy that would spend any time in the attic.
This house has 10-foot ceilings, and this 16-foot extension ladder is light and easy to extend. I extend it up until it hits my attic hatch and then push up on the ladder to open the hatch before locking in the ladder. The 16-foot extension ladder works fine for me but one of these days I would like to replace it with stairs. Maybe one of these days…
For outside antenna work I bought one of those “Little Giant” 26-foot combination ladders. These can be used as step, extension or offset ladders. They have latches that allow the thing to be converted in various ways.
While a neat idea, it is really heavy and hard to wrangle by myself, especially in “Extension Mode”. Also, in extension mode they are not really steady, they have a lot of flex. I used this to install my Omni-X and ST-2 on the side of my house and was not comfortable at all. I had to extend both legs to their full length and then pick the ladder off the ground to get it to the roof, not an easy task. I could not extend it while it was vertical, the thing was just too heavy to do so.
I then decided to do things right and get a bigger, standard extension ladder. As a “man of size” as they say, I needed a ladder with higher weight capacity and 22 feet or more reach. I remembered from 3 decades ago in my firefighter days that we had Werner fiberglass ladders for groundwork, so I looked for these. At Home Depot I found a 24-foot Werner ladder with a 300-pound capacity. It was expensive ($400), but I knew it would last and support my less-than-petite frame. I could carry and set it up by myself easily. My wife would help but mostly she would get in the way so that was important for me.
I brought it home and used it that afternoon to swap the ST-2 for my Mil-Omni. It was perfect for the job! As expected, it was easy for me to wrangle and a whole lot sturdier than my Little Giant. Now I had to figure out how to store the thing. At 12 feet long when not extended it would always be in the way no matter where I put it. I really wanted to hang it on the wall in my garage, but I had cabinets on one side and work benches on the other. I looked at other solutions and my wife asked about hanging it on the ceiling. Aha!
I found the weight to be about 50 pounds so thought about a pulley. My brother-in-law had had his kayak stored on his garage ceiling, so I checked Amazon for a kayak pulley and bought a “StoreYourBoard” system rated at 150 pounds. Basically, you mount two pullies on the ceiling, screwed into joists. You then rig the rope thru the pullies. It has straps for the load. The hardest part of installing it was figuring out the rope route thru the pullies.
Ironically, I had to use the Little Giant to install the silly thing on my garage ceiling, it was the only way to reach it. Once installed it took some time to figure the operation out, but I found that the easiest way was to set the ladder on my wheel cart and position it under the pullies. I then wrap the straps around the ladder and pull the ropes, lifting the ladder. It has tension stops to prevent it from falling, I then tie off the rope on a bracket on the wall. Easy-peasy!
I have used this Werner ladder several times now, most recently this spring when I changed the coax lines in my attic. In order to connect the new coax and remove the old one I had to get on that ladder outside. When I do this type of work, I use one of my 5-gallon work buckets to hold my tools and supplies. I also have a set of oversized carabiner style hooks to hold the bucket to the ladder while I work. These hooks fit nicely on the rungs of the ladder.
Going back to the attic, the smaller, lighter aluminum extension ladder is better for accessing the attic, the Werner is too tall for this work. I tried and failed. My thought was that I could use just the one ladder for both and found that I am better off with using two. The painting ladder is still useful for other jobs around the house but is too short for any of my antenna work.
If you are going to work on antennas at elevation, be sure to invest in a proper ladder. $400 is a lot of money for a ladder that I will use a couple times a year, but it is worth the investment. It will outlast me for sure. Just the secure feeling I have on the Werner compared to the wobbliness of the Little Giant is worth the expense.
ofd8001
Louisville, KY
Just the other day I was at the firehouse and watched a guy climb a ladder. I asked him if he could count any higher while on the ladder. (Real old fireman joke :) ).
GlobalNorth
Fort Misery
I need to use a larger ladder, but after pricing one and transporting it home, I decided to rent a suitable ladder from a local construction rental supplier. They drop off, give instructions, and pick up - much less hassle for the elderly user.
evilbrad
My head makes a bad antenna
I need to find a photo I have of this. Antenna was one of those over sized booms cb yagi. Rather then have right mount and arrangement put together by someone inclined they had this Antenna mount contraption hillbilly setup on this roof. They had a stepladder holding it up and the stepladder half a$$ed guyed with a make shift guy system. This was on a roof mind you.
evilbrad
I cant make this up Rich have u ever seen anything like this?. I would love to see the comments on this from tower experts.. -;)
N9JIG
Sheriff
Moderator
Far NW Valley
I married a holler chick, I have seen it all! You can take the chick out of the holler but you can't take the holler out of the chick.
My redneck brother-in-law had a window-mount AC in his pickup camper, he built a "garage" out of plastic roofing sheets, covered by a blue plastic tarp.
One thing he did that I liked was when his step ladder broke he sawed off the bottom half and his wife made a planter stand out of the top half.
There were a few guys that used step ladders as antenna mounts at various Field Day events over the years but I guess that fits in with the whole concept. At one field day at a local picnic grove we stacked picnic tables to form a ladder of sorts so we could pop a few antennas on the picnic shelter roof.
kc8jwt
Belpre, OH
I work in a school district in Ohio and every summer we always seem to have a project going on. Six years ago we were changing out wireless access points in all of our buildings. We were working in our oldest building and I was going to swap out an access point in the old gym. This access point was located up in the old scoring stand above the doors going to the outside. You had to take a ladder up into the stand. I then had to use a 6 foot step ladder in the stand to reach the enclosure the AP was in.
When I went to fold the ladder out, it lacked about 3/4 of an inch being able to set correctly. I then turned the ladder around and just leaned it against the wall. When I went to take the enclosure off the wall, the anchors that the contractors used to keep the enclosure on the wall were being the tile type material and were just spinning. I was able to pull three of the out with a little bit of work, but the fourth one was spinning free and I needed the anchor to grab to the screw would come out. I put pressure on the enclosure to pull it out so I could unscrew the screw from the anchor. It let go and the enclosure hit me square in the face. I lost my balance falling backwards. I then hit the top of the stand and trried to grab ahold of it to keep from falling. I couldn't get a good hold and kept falling and then stuck a metal railing beside the cast concrete bleachers falling to the floor.
When I hit the floor I knew I was in trouble. I was bleeding from my face where the enclosure hit me. I also knew that I had broken my leg. I broke my left femur. I had broken that when I was 17 in an auto accident and as a result had a metal rod already in my leg from that accident. I had a student worker with me who was freaking out the whole time. I was able to get him to calm down and call 911. After he called 911, I had him call central office to tell them that I had an accident and to call my wife. I then had to tell him to go to the outside of the building to me the medics so they could get in. He was worried about me and he was like, "Don't move!" I told him not to worry because I couldn't move.
They ended up calling the fire department for lift assist and I ended up being transported from the local hospital to the next closest large hospital which was Ruby Memorial in Morgantown, WV. Luckily, the doctor on call that night was the cheif of orthopedic trauma surgery and he was the best.
I eneded up being out of work from the end of July till around the end of September. I was able to calculate how far I fell and it was 18 feet. Eveyone has said it was a miracle that I wasn't hurt any worse than I was. I ended up with a broken femur, a cracked scapula, and 4 stitches above my eye. As a result, I have been banished from using a ladder at work.
evilbrad
Before I moved a buddy got a manly lol lift. Only issue is he didnt have trailer? Or truck to really move it around. So it takes finding one or trailer. But I wished I could have used it before I moved lol.
I sent that to a guy at a tower company once for shoots and grins lol as NATE training example of what not to do.
evilbrad
University i worked at summer meant office moves and where they want the office doesnt always have right access to outlets or cable connections. So ladders and crawling in building attics in summer was so fun.
