ICOM F-121S for Allstar
DODGEIT
Kodak Tennessee
I recently put together an ICOM F-121-S as an Allstar Node Radio. Basically used the OPC-617 cable and had made a transition cable that plugs into the DB-9 on a Masters Communications RA-35 soundcard device. The only thing I wish had been done is that this setup used discriminator audio which means you have to set the volume switch to the 11:00 position to get the audio out. Minor inconvience but it works well. Also had to set the COS to usbinvert in the simple tune menu in Allstar.
