Icom F5021 Programming
To program the radio you will need that software, the link you included is correct.
Some radios have options for making minor programming changes via the front panel with some special key press sequences. My old Icom F-2020 had a way to do that. It didn't let you change all the options, just a few. To do things like setting channel names, key assignments, etc, you will need to use the programming software and the cable. You -might- be able to find a cheaper cable on e-Bay, but they are usually not factory, and some of them are low quality. Since it is not your radio, I'd make sure you use the correct stuff to prevent any problems. The price at Antenna Farm is reasonable.
rapidcharger
The land of broken calculators.
Some of those Icoms can flashed for field programming. Called dealer mode.
It pretty much just lets you change the freqs/tones/alpha tags but not much else. You'll need to devote a PF button to it and as it is there never seem to be enough PF buttons. And of course then it loses it part 90 cert I think.
Avery93
AL
Correct, except it actually doesn't take up an extra PF key. The dealer mode is entered by pressing a combination of buttons while powering the radio on.
As mmckenna said, you will need to initially program the radio with software to enable dealer mode. In addition, you will also have to enable a hidden tab in the software, to get to the screen where you enable dealer mode.
billy2moto
Fort Lauderdale, FL
I'm programming one now. There is no dealer mode, just a user set mode where a few seldom changed things like squelch setting, beeps, mic gain can be set. The programming software (got mine from the antennafarm) is needed for zone, channel and key assignments. It is fairly easy except I can't figure out how to delete a zone or channel once added. Nice little radio.
Avery93
AL
The F5021, and as far as I know, all newer generation Icom radios do have a dealer mode where basic channel information (TX/RX freq, PL/DPL, bandwidth and name) can be edited from the radio itself. It is in addition to the user set mode, which is also available on older series radios. Activating it involves accessing a hidden part of the programming software, enabling the dealer mode there, writing the new programming to the radio, and holding down two buttons while powering the radio on to actually access the dealer mode on the radio. Google "Icom maker reserved" if you want more info.
(Note: If you do this, make sure you first read the exact radio you are going to write to before you enter the maker reserved mode, and do not change any settings in that area other than the one necessary)
To answer your question about deleting channels and zones, it is a fairly simple process. To delete a channel, simply highlight it and press delete. To delete a zone, just delete all channels in that zone.
