Hey all....got a bit of an issue. So I just completed the install of an IC-7300 along with the AH-4 tuner and a 136' long wire antenna. So far, I have zero activity on the transceiver and haven't been able to receive anything really. If I turn the REF dB up to around 20 I can see the waterfall etc. but still no signals. I used Random Wire Antenna Lengths to determine 136'. It is connected to the AH-4 and then run up the side of the house and around the upper roof....it's around 35'-40' high.
This is my current setup:
ICOM IC-7300 TRANSCEIVER
ICOM AH-4 Antenna Tuner
LIGHTNING SURGE PROTECTORS (2)
ANTENNA WIRE
GROUND WIRE
GROUNDING RODS (3)
JUNCTION BOX
COAX
COAX CONNECTORS
COAX COMMON MODE NOISE FILTER
ROOF CABLE CLIPS
Various other connectors, chokes, sealant, accessories etc.
I've reset the IC-7300 back to factory settings and checked all COAX connections. I also have read the IC-7300 manual and made all the adjustments available. Still, no reception of anything. The spectrum scope also shows nothing. I've also installed the VHF/UHF antenna in the pics and it works perfectly. The HF install is of the same quality. Any help is appreciated! Thanks.
ANTENNA WIRE
GROUND WIRE
GROUNDING RODS (3)
JUNCTION BOX
COAX
COAX CONNECTORS
ROOF CABLE CLIPS
