rsqemt911
i recently bought an ic-f50v and programmed it yesterday. the radio works well with the exception of 2 problems. no matter what i do i cannot get it to vibrate or do voice record. i have gone through every menu and read the help files and nothing works. i have it set to vibrate when turned on and vibrate when i get a 2 tone alert. the radio trips for the 2 tone alert but does not vibrate. i also set the p04 button to be playback/record and when i hold it down it does nothing. if i tap it it just lets out a beep letting me know thier are no saved voice messages. the radio is set up to record voice traffic on 2 tone as well which it also does not do.
i have a decent amount of knowledge in programming radios (mostly motorola) and was able to navigate my way through a great deal of the features in this radio. i know what the radio is soposed to do and was able to figure out most of the things i want even though the layout in programming is different.
i have checked off enable on every menu i could find in the radio related to these 2 features and nothing works.
i know with motorola radios you can enable almost everything and if you leave 1 thing in a menu out it won't work (lots of redundency) but i am really at a loss here. of course with motorola, if you leave somthing off and thier is a conflict, usually it will give you a warning message before you can send the codeplug to the radio and link you to the spot on cps you need to fix.
other than that issue, i really like this radio and am looking forward to getting this up and running fully.
thanks
Robert F. Curley EMT-I, EMS-I
Seymour Ambulance Association
Echo Hose Ambulance Corps
thanks
