It looks like my Palm IIIxe has suffered some pin corrosion probably due to rechargeable battery leakage.
The on/off switch is still a bit intermittent and there is some low level green corrosion on the 10 accessory pins.
I think the original inverter whine was from the backlight electronics although it was not illuminating. I can switch on the Palm IIIxe but the switch is intermittent. However I cannot enable the backlight. I probably need to open the Palm and use some contact cleaner on the power switch and accessory pins
