I've been looking for a wide band receiver/scanner that would have coverage that my Pro-106 lacks. Some of my wide band radios that I've had in the past were the AR 8200Mk2 & 3 and the Yaesu VR-500 . Both were my favorites for some time, then trunking and digital came along and I had to keep up with the technology.
After several nights of reading reviews and a taking a quick glance at the IC-R20's owners manual I was hooked. I' am in awe with the quality and build of this radio. The LCD display has to be one of the best one I've seen in any scanner. The display has several font sizes that adjust depending on what mode you're in. Its very easy to read with or without the green backlight on.
One feature that I really like is the bandscope, this radio has two of them and you can sweep both at the same time! Another jewel in this radio is a digital recorder . With it's 32mb of memory you can record up to 4 hours of radio transmissions on the fly, or set it to record automatically when squelch breaks. You can playback the recordings with ease with one touch of a key. I prefer the high quality 1 hour setting.You can also monitor two frequencies and hear them both at the same time ! The CS-R20 software takes a little to get use to but does the job and make programming the R20 a lot easier. It's a shame that Butel gave up on ARC20 , Gommert are you listening? As you can tell I 'am impressed with the IC-R20.
