Back in the mid 80s I purchased A Icon-R71a to replace my unrepairable and warn out Hammerlund HQ120. The icom has very low hours and was stored for about 15 year and thought the other day about setting it up again. I decided to bench test it before getting into running a new permanent long wire antenna so i ran a temporary 75 foot run and found out that for some reason the Radio now has very weak audio. even when tuned into local AM with the audio gain turned all the way up it is very low in volume and barely hear the stations. It did not have this problem when it was put away and now I think It needs to go into repair. Also I am not sure if it is worth the repair cost since you can get the IC-R75s used for the $350 range and a new one for $700. The questions I have are below.
1) Is this a known problem on this radio?
2) Does anyone know of a good radio guy in the Palmdale, Lancaster area in California. Or even the S.F. Valley
3) Anybody have an idea what the problem is?
4) Is it worth fixing? and how much should be spent on the repair?
