Icom R-20 , BC-149A Charger Runs Fairly Hot..Is this normal?
N4UMJ
Just wondering... I picked up a used R-20 with a BC-149A wall transformer and found the power supply to run fairly hot. Mine even had a slight electronics smell to it as I charged the R20 for the first time. The unloaded voltage out was measured at 6.2Vdc and it's rated at 1AMP so I am figuring there must be a big regulator on a heatsink inside. With the many vent holes I observed on the rear and sides I suppose should signal this is a hot running power supply.
Doing some calculating I am figuring 117 VAC @ 300mA input and 6Vdc @ 1000 mA output comes out to be 35.1 watts input and 6.2 watts output. So it appears the efficiency is not all that great and that would explain a lot. I did not see any notes in the manual about the X-fmr running hot and I do remember another ICOM 1 Hr quick charger I owned ran on the hot side(it was a LI-ION battery powered HT).
I'm having a fun time operating my new R20 and using all its features and seeing how it stacks up against my older R10!
Ed
N4UMJ
bsdam
Livingston County, Michigan
Ed,
I've never noticed my wall transformer getting anything more than slightly warm. Maybe it is on its way out?
I love my R20 too, great radio, durable, and the battery seems to last forever. Awesome rig!
-B
Ed
N4UMJ
nanZor
Yes, it runs very hot on both the R20 and the new RX7. I had the exact same experience when I first got the R20 and was a bit surprised at how hot the BP-149 linear power supply became.
nanZor
Just ran a test on the BC-149A under a "kill-a-watt" meter:
Under no load / idling: 2 watts
Charging: 6 watts
Charge and operations: 7 watts
Since I only use the adapter for charging and not permanent use, I opted for a much smaller, lighter, and cooler switching supply. Both the R20 and RX7 use a RS "adaptaplug C". Here's a rundown on the #273-333 and 273-029 switchable voltage adapters (both similar only the 333 is rated 2A and the 029 rated at 1A. Results are similar:
(note: the 273-333 comes with 3 adaptaplugs, one of which is the "C" size.) The other adapter I had to get the plug separately)
No load / idling: 0 watts
Charging: 2 watts
Charge and operations: 3 watts
However, since they are switching, there is a bit of switching noise heard on BCB and HF AM. 30 mhz+ is not a problem. The antenna I used was basically a few feet from the adapter, so perhaps a remote antenna, with chokes on the feedline might reduce this.
For me, I travel with these switching supplies just for recharging, but the less efficient BC-149A linear supply is much quieter if you use these portables as fixed stations and listen to HF.
