The R75 is not like a scanner, as such you really cannot pick one "all band" antenna for it that works equally well on "all bands". Even though it is only 60 MHz of frequency it still covers many, many bands, in fact a couple of complete pieces of spectrum (LW, MW, HF, and part of VHF). A scanner might easily cover 420 to 470 MHz, and that is 50 MHz, and a single antenna will cover 420 to 470 MHz very well. But when you look at the bandwidth as a ratio of frequency (and you must do so when designing an antenna) you can really equate that entire UHF band to one small chunk of HF, for simple math lets call it 4.200 to 4.700 MHz, only 0.5 MHz.
For antenna design function, with regard to bandwidth, these two radically different bands are very similar in limitations.
So, to cover the popular VHF/UHF scanner bands you can design a single antenna, pretty easily, to work 30-50 MHz, 140-175 MHz, 420-470 MHz, and 900 MHz. Sure, it will not work very well between these bands, but relatively few people spend a lot of time "between" the popular bands on VHF/UHF. Yes, I know I am leaving out important things like the VHF aviation band and the UHF mil-air band, but I am using this as an example, not as an all encompassing.
Before someone says "discone", the discone is a compromise antenna that does nothing well, but does a lot of things OK. It is often quoted as a "unity gain " antenna, but in fact it is not really unity gain across most of its typical operating range as applied to VHF/UHF scanners, it is unity gain in its most efficient ranges only. And yes they can be built and used on HF frequencies as well, with the associated size increase, think one 30 to 50 feet high as a good starting place, taller if you really want to cover the entire MW/HF range.
But, the range covered by the R75 is 30 kHz (0.03 MHz) to 60 MHz. And in very real terms almost the entire range is used, with few gaps as found on VHF/UHF. You could equate, for purposes of antenna design and bandwidth as a function of frequency covered, this to a "scanner" that covered 30 MHz to 60000 MHz (yes, that is sixty thousand MHz) and trying to find one antenna to do that entire range with no gaps. It just ain't gonna happen with flat, equal, performance across the entire range.
So more typically with a radio like the R75 and a situation when you can only have one antenna you pick the part of the spectrum covered that you are most interested in. Say the Marine bands in the 8 and 10 MHz range. You build/buy an antenna optimized for those ranges and you accept that it might not work quite as well, but will still work, in other ranges. It is possible to pick a "wider" banded antenna, one that maybe works 5 to 25 MHz, or even 3 to 30 MHz, but given the same amount of cost and effort, and area, that will NEVER work as well as one designed for a smaller band within the small band that antenna is designed for.
Wide bandwidth in an HF antenna is a compromise, and compromise means it works less well in some areas, and almost as good in others.
You want "best" performance you build an antenna for each chunk of spectrum you are interested in, no "single" antenna will do it. But often one can find "acceptable" performance with a compromise design.
Some people put up multiple compromise antennas. For example one antenna for 2 MHz and down, covering LW and MW. Another antenna for 2 MHz to 7 MHz. And another antenna covering 7 MHz to 30 MHz. Then again other people only have room for one antenna, and must "make do". As a general statement the multiple antenna approach will often result in better performance, but the single antenna is often “good enough”.
As another general rule size matters with HF antennas. A full sized half wave dipole for any frequency will almost always outperform a "reduced" size half wave, say a loaded half wave, for the same frequency. And the full sized antenna will have wider bandwidth, or a larger efficient operating range. And a full sized one and one half wave antenna, with its associated larger capture area, will most often outperform a half wave dipole. If you have the selection of two antennas, both made for the same band or range of frequencies, and one is physically larger than the other, and you can support the larger size, selecting the larger antenna will almost always be the better solution.
Yeah, OK, I did not recommend any one antenna here. Realistically, with the amount of information the OP gave, one antenna cannot be recommended. How much room is there for antenna construction? Is it an apartment or a house? Is the house on a city lot or a country area with acreage? What is the cost bracket allowed for antenna purchase? Are you able and willing to build pieces parts yourself? If you can handle simple hand tools it is possible to build a relatively acceptable antenna for fairly low cost. What kinds of signals are you most interested in? Ham listening? Spy numbers? Shortwave broadcast? Military comms? HF aviation?
All of the above questions, and more, could go into selecting the "best" antenna for your application.
T!
