ICOM R20 Owners
no
no,you worry too much,Each band is represented by a frequency say HF is 1.800 MHZ . am is 0.495mhz
you can always put the settings back as long as you wrote them down.
the settings I have work great,before I could barely hear HF at all,it sucked,I had it for 1 day and i wanted to sell it.
Comparing it to a Yupiteru 9000 its right up there now. 440 mhz is ok I didnt touch that.
Now Im keepin it and putting in an audio board to ramp up the audio output,my sound is good with the new speaker so far,now I need louder!
Nothing ventured ,nothing gained.....
https://www.sparkfun.com/tutorials/392 <im gonna try to ram this in there.
settings do this if you like using the antenna it comes with!
This is what I did ,put test jig in ,once on,pull jig out ,open yer squelch whenever it isnt open for every move below.
The first setting does the most to me anyway,
this comes up first .
00 (REF) ---------------------------------------------------------------------------This is the page you cant change it.
20 my setting < turn knob on top to change --------------setting
B:FM --------------------------------mode YOU CAN CHANGE THE MODE NORMALLY
1285.000.000 --------------frequency (this is reference)
press 8 and .LOCK <<this locks it in !do it quick!
next hit scope until you get to -------scope pages you forward to the next setting.
1D (S-M)
75 my setting << Keep hitting AFC to get this with squelch OPEN
B:FM
435.100.00
done hit SCOPE until you see : (not if you pass it it loopsback)
17(S-M)
69 <My setting hit AFC to get there with squelch OPEN
A:AM
14.100.00
done Hit scope several times to get to
16(S-M)
67 <my setting hit AFC to get there with squelch OPEN
A:AM
1.810.00
done hit scope several times to get to
10(TRL)
OE <<<Turn knobs on top to get to this value
B:AM
118.100.00
8 and LOCK to lock in both QUICK
hit scope
OF(TRH)
B2 <<<Turn knobs to get to (one knob goes forward one goes backward) this is HEX value!
A:FM
469.900.00
Scope
OC (TRL)
0C <<Turn knobs to get to
A:FM
118.100.00
8 and lock to lock in both quick!
Scope
0B(TRH)
7F Turn knobs to get to
A:AM
1.620.00
scope
OA(TRL)
40 use knobs to get to
A:AM
0.495.00
8 and lock ,lock in both quickly
scope
shut off and turn on .
Note :i adjusted for highest "noise" signal .You can play ,but remember BEFORE you do anything write down the values before you change them!
volume and mode works normally in this mode! <<<<<IMPORTANT
Test jig is a shorted left and right STEREO jack not mono,ok?
Not responsible if you dont like it,remember I told you,write down old values so you can change back.
