Icom R5 data cable schematic
MidNitRcr
Does anyone have reliable info on building the data/programming cable for the Icom R5 radio?
I've found a couple different plans, but they seem to be conflicting. I was hoping someone on here had built one before that they know is safe to connect without overloading the radio or serial ports...
Comint
Queensland, Australia
Attached is the circuit diagram for the actual OPC-478 cloning cable.
Comint
MidNitRcr
Yep, you are correct...
it took a couple days to put together all the right parts (and I substituted in for some values that I had laying around) but as long as you get it close to the diagram it should work just fine for the IC-R5....
