Icom: ID-52 - need help troubleshooting
macaw2000
I picked up an ID-52 but can't seem to receive anything.
Even FM radio isn't coming in. The speaker works. I played with the squelch. Any ideas where to start looking?
Whiskey3JMC
LMR Explorer
Philly burbs 🇺🇸
Welcome to the RR forums. Assuming you're trying to bring in an analog signal in VFO mode you'll need to make sure you're in FM or FM-N mode & don't have a tone squelch or DTCS tone set. If you do, no traffic will pass through unless it matches that tone. Refer to Section 15-8 of the user manual
1� Push [VFO/MHz] to enter the VFO mode�
2� Push [MODE] to select the FM or FM-N mode�
Make sure this is set to "off" for all traffic to be carried
macaw2000
TY for the quick reply. I did verify I was in FM and Tone was set to OFF. I'm programmed Tone and DTCS in other radios when I wanted to connect with a repeaters but they appear to be off. The scope shows signal coming through btw, I just can't hear it. I feel like your advice is on the right path because of that but I haven't figured out what.
AE4NG
Port St John, FL
I know it may not be too much of help but have you tried resetting the radio to see if it fixes the issue? A lot of times a full reset can usually fix any simple issues. It’s just a thought.
