Ignition Control Fix . . .
NF9L
Kansas City, Missouri
I have been re-programming wide band MaxTrac mobiles I got from various police dept. for Ham use and it's been great. I have run into a bunch that don't power up without connecting 12 volts to the ignition control pin 10 on the 16 pin models and pin 1 on the 5 pin models.
Does anyone have an easy way to get the 12 volts permanently or do I always have to just add a wire from the out side to add the 12 volts. It kinda complicates the power hook-up cable.
any suggestions . . . thanks
Georgia
I am no expert, but since you have to run power to the radio, couldn't you just use a splice and tap right into the red positive wire right at the radio for the permanent solution? Just my two cents!
cmdrwill
So Cali
The little green fuse usually has one end cut for IGN use. Resolder the fuse back in, or replace the fuse.
LittleFuse 2A axial leaded, looks like a resistor, located near the 16 pin connector.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Been a long while since I peeked into the RSS, but isn't there a setting to enable/disable ignition control in the software?
cmdrwill
So Cali
No, there is no setting in the programming on the Maxtrac, Radius, GM300 radios for IGN control.
