I'm all setup, lets stream!
garikfox
Queen Creek, AZ
I'm all setup, do i sound ok?
Hello everyone, I've spent the past two days tuning my feed here in Arizona. I think I've got it pretty good.
May i ask some of you to test my new stream here from Arizona ?
I'm very curious and interested in what your all opinions are since I've never done this before.
https://www.broadcastify.com/listen/feed/28407
Thank you,
--Garik
Thank you,
--Garik
Been listening and it sounds real good, glad you have the IDs on the feed.
NYRHKY94
Brunswick County, NC
Nice job. Sounds good to me as well. Hearing a slight hissing sound in the background, similar to what I experienced running a feed using the headphone jack on my BCD436HP. I used a ground loop isolater to take the hiss out. Nice to see alpha tags on the feed.
garikfox
Queen Creek, AZ
Thank you guys! I appreciate your input.
Yeah i hear the hiss too, thank you i'll get a ground loop isolator.
KC8ESL
Mentor, Ohio
A hiss is not indicative of a ground loop, that would be a 60hz buzz. A hiss suggests that you're running your preamp on your feed providing computer too hot and not enough output from the scanner. Try turning up scanner audio and turning down the preamp on the computer. This is known in the pro audio world as "gain staging".
garikfox
Queen Creek, AZ
I think I fixed it! :)
I put the Recording Volume to 75% from 100%, and the scanner volume to 10 from 9.
Edit: Not fixed, lol
NYRHKY94
Garikfox:
Just an FYI. In my own personal experience, I found it challenging to run a clean, hiss free feed using the headphone jack on the BCD436HP. The REC out jack that Uniden used to provide on the back of their previous versions of base scanners was ideal for running feeds (nice clean audio). The best feed audio I have experienced to date is using the Wifi feature on the BCD536HP. No cables involved, which eliminates lots of potential audio issues.
In any event, when I inserted the ground loop isolator below between the audio cables running out from the headphone jack on the BCD436HP and the "Line-In" on my PC sound card...the hiss I was hearing was significantly reduced. Again, just my own experience.
Very nice job on your feed!
Mike
flythunderbird
Grid square EM99fh
If the ground loop isolator doesn't remove the hiss to your satisfaction, you might try adding a noise gate to the audio signal path. The gate blocks the audio signal until the signal exceeds a level set on the gate. There are both hardware noise gates and software noise gates you can try ... there are a few free software gates out there.
Both of my feeds use hardware noise gates. The gates are part of a dbx compressor I use to level out the feed volume.
NYRHKY94
That one looks like it's worth a try. Best of luck!
P.S. As all of us have said, your current feed is really good slight hiss and all :)
NYRHKY94
Me too, especially when it comes to feeds ;-) I tweak and tweak like there is no tomorrow. When I set-up my first Wifi based feed using the BCD536HP, I found nirvana. Pristine audio with no input jacks, sound card or cables!
