Good Morning all,
I have used the Imax antenna(s) for as long as they have been made.
A-99 before that. 1st as a CB'er and free-band DX'r .. now as a HAM. I have a habit of leaving them when I move away. Over the past 18 years or so they have more than doubled in price.
NOW, the manufacturing is from China.
This past spring, From Feb thru may, I bought one off eBay that included FREE SHIPPING ! That's important since its an 8ft. box. Shipping is OVER a $100.++dollars now. I have NEVER had a problem with an Imax. And I've bought 6 or 8 of them.. This time around the first two I received were "electrically" broken in the base section. I used an antenna tuner and multi meter.. all to check the coax, antenna and hell even the output from the Tx'r .. I was able to track the break into the base base section.
the first TWO would not Tune on ANY frequency.
Thank God, I bought mine off eBay "motors" section which guarantees the purchase.. as returnable. The total cost was about $230.00 SO even thought I made my purchase from a "can stereo, accessories vendor" They couldn't replace it due to NO STOCK. The actual distributor was "ROAD-PRO BRANDS" and they stood behind the purchase, after I received the 3rd, It was plug and play.. as usual.
Consider this.. what's it for?
- The solarcon ground plane kit is ONLY eye-candy. It has no beneficial electrical effect, because it's TOO short in length
- IF for Rf issues, You can use clamp-on Ferrites to eliminate the Rf from coming back down the coax (use enough!) at the base of the antenna. I did the math here also.. about 9-11 of these will stop Rf.
- If to lower your take off angle, really maximize the MAX.. read below...
IF you do your homework and read about the actual benefits of a GROUND-PLANE.. The ground plane kit offered by Solarcon is absolutely WORTHLESS.
It is NOT electrically VISIBLE to the Imax. ( READ online about "ground plane design and length of radials for desired frequency ) After doing my math and shopping available resources ... I did build a
PROPER ground plane system for the Imax. It
REQUIRES a little material and shop skills. For 10/11 meters 26-30 mHz, You must have at least FOUR
8 foot radials (
Stainless Steel whips are great and available).. To create the perfect TAKE-OFF ANGLE for worldwide DX'ing.. I mounted SIX (6) 8ft. S/S radials in a circular pattern using a "L" shaped steel plate which screwed onto the Imax /mast bolt holes, and the radials were screwed in at 90 degrees.. to standard 3/8's x 24 thread nuts which were welded onto the L shaped plate. I am going to do a quick draw.. so you can see what I'm failing to describe.. THIS thing allowed me to work
OVER 140 countries worldwide ( 27.555 usb) confirmed by QSL cards and on while using on local side-band rag chewing... I could hear others that my friends could not hear. The antenna was mounted at 36ft. off the ground. I've had them up as high as 110ft. atop my 100ft. Rohn tower. The 36ft. height off the earth was AS or MORE efficient than at 110ft.
This all seems like a lot of effort.. IT WORKS!
Trust me .. I'm a doctor.
73'
Ed
N4EDX
