IMPORTANT ANNOUNCEMENT ON KENWOOD AND EFJ ITEMS
kd4efm
EL98 Florida
What is the difference with this cable vs the KPG-36x ?
the cable is straight USB with nothing in between (native to the 5/6/7/8000 series radios)
(think of it like a type A USB to micro-usb - Viking mobiles all have the Micro USB on them)
wd8chl
I wonder if FW would be faster with that cable...although it seems like most of the time is internal to the radios...
kd4efm
EL98 Florida
PRICE CHANGE ANNOUCEMENT
KMC-40 & KMC-49; MIL-SPEC Speaker Mic with Antenna Connector
Effective Oct 2022, price increase for the antenna mounted speaker mic will take effect.
Contact your dealer for more information
mark_dunkle
USA
Kenwood will charge you even more for that cable than they charged for the KPG-36X. Bend over.
kd4efm
EL98 Florida
NXR-1700E VHF Repeater with optional DMR add on can now be ordered.
KPG-D7 - NXR-1000 Series Repeater Software can now be ordered.
Contact your Local Kenwood Dealer for more info,.
kd4efm
EL98 Florida
Need to revise my statement. NX3K version 4 and NX5K version 5
adds Priority MONITOR to dmr Trunking, and to P25 Trunking.
kd4efm
EL98 Florida
NEW UPDATE TO KPG-D3_K RELEASED. 4.01
Contact your dealer for more info.
VERSIONS TO DATE
KPG-D1 - 5.01 NX-5000, 5000s, TK-5000, AND TK5x30 SERIES
KPG-D3 - 4.01 NX-3000 SERIES
KPG-D5 - 1.02 NX-P500
KPG-D6 - 3.10 NX-1000 SERIES
KPG-D7 - 1.01 (INITIAL RELEASE) NXR-1000 SERIES REPEATERS
kd4efm
EL98 Florida
JVCKENWOOD USA Corporation JVCKENWOOD USA announces final order placement and discontinuation for the KNB-L3M Li-ion battery.
KNB-L3M will be available until the remaining stock is depleted.​
JVCKENWOOD USA announces the release of the KNB-L11 3,900 mAh Li-ion battery. The KNB-L11 replaces the KNB-L3. The KNB-L11 can be charged only by the new KSC-52AK charger and the KSC-526K 6-unit charger with the new KSC-52PAW charging pocket attached.
Contact your local KWD dealer for more information
kd4efm
EL98 Florida
LICENSE MANAGER UPDATE
Version 2.01 is out at this time. Get with your local dealer or rep to obtain the latest copy.
AM909
Radio/computer geek
SoCal
"Viking Subscriber Software 24.1.1 Maintenance Release" (v1.42.15, released today) replaces "Viking Subscriber Software 24.1 General Release" (v1.42.12, released a couple weeks ago), which should not be used, as it can corrupt some CTCSS values in codeplugs.
n7maq-1
Oregon
xx.15 still has an issue with 151.4 CTCSS
otobmark
NC
ARMADA 1.42.15.218 Still 151.4 problem and work around
Newest CPS still has the 151.4 problem in that when you try to put in 151.4 from drop down menu it instead inserts 67.0. My radio has FPP so by using that I was able to set the CTCSS to 151.4 manually on the radio itself. Initial brief test with another radio showed the tone to be functioning in and out but please test for yourself to verify. This would suggest this is strictly a CPS problem and not a radio/firmware issue.
AM909
Radio/computer geek
SoCal
New: Viking Subscriber Software 24.1.2 Maintenance Release, dated June 18, 2024, contains Armada 1.42.17 (the only change from 1.42.15) that fixes the 151.4 and 79.7 Hz CTCSS bug. It replaces 24.1 (1.42.12) and 24.1.1 (1.42.15).
kd4efm
EL98 Florida
Dear MEMEBERS AND NEWCOMERS
Please take this as information for any and all future PC purchases.
From KWD Tech Support;
Hey Evans .. our official reply is this platform is not supported.
Not to say some users have got it to work, I think they may have but we don’t say it’s compatible.
Only Windows NON-ARM BASED Processor pc's is our official support for KPG-D1N and other KPG-D FPU's.
This includes the Windows Surface Pro devices with SnapDragon.
