Impres Battery Issue
RSQ911
AEMT
I have an Impres battery that has stopped charging, whenever I drop it in the charger is will flash yellow for the Hot/Cold error, If I put it in a radio, it will still turn on. Is there a way to get it to stop doing that or do I need a new one?
buddrousa
Not owning that radio that should be a battery error. Others have posted here that some aftermarket batteries do not play well with the chargers so either buy Motorola Battery or from a place that accepts returns.
RSQ911
AEMT
It is a Motorola Impres Battery that I got from Motorola as it states above. Thank you for your input, but that does not help me.
RSQ911
AEMT
Your charger reports you have a battery problem as i stated above. The other advice to save you money. Sorry that is no help.
My apologies, the way I read your message was different than what I believe you intended to convey.
K9KLC
Southwest, IL
What does the capacity and battery life say in the radio? (assuming you have a radio that will show that you don't mention the model of the radio) How old is the battery?
RSQ911
AEMT
It is an APX1000 however when I open the battery tab it says not available and gives me the low battery chirp. I attached a picture of the battery
