Increasing Scanning Reception - MPSCS
nvanw27
WSDU482
Kingsley, MI
I live between a few MPSCS towers - I'm pretty much equidistant between South Boardman and Manton, and I can receive River Central despite being a little further away from it. I am unable to get anything from Manton or Rapid City. I've tried a stock Uniden BCD325P2 antenna and a magnet mount antenna for a car as well - no dice. I know I should be able to receive South Boardman and Manton from where I'm at, I'm just not sure what I need to do to be able to receive off of those. Any antenna/mounting/setting recommendations?
dmchalmers
I hope to hear a reply also I'm just outside of the Treetops sites range an the west branch site using a discone on a 35' tower
jimsokol
SW Michigan
I no longer have this model and am trying to remember the display, so forgive me if off a little. Do you see signal bars in the top right when it scans the control channels programmed or "DAT" next to the freq?
hanlonmi06
Pittsfield Twp, Michigan
One thing I always revert to when troubleshooting reception is to click over to the NOAA freqs. I know roughly what stations to expect to hear and at what strength. If I think I am having antenna problems that is one possible quick way to know whether its antenna or "programming". If the weather reception is good to go, then I start digging into configurations of my MPSCS stuff. If I am not getting weather reception then I know I have hardware problems.
hockeyref2
Northern MI
Put a yagi on your roof pointed toward the site? There are some close sites that I can't hear, and some farther away that I can.... There are terrain features in the way.
Then some sites I can get OK most of the time, but sometimes I can't.. I that gets into weather effects, foliage, RF noise, etc.
I used to be able to get Manton for months, then one day it was gone.
buddrousa
As posted in POST #5 you need line of sight from antenna to antenna.
1. How far are you from those sites in miles (no guessing)?
2. What is the terrain like between you and them?
3. Can you put up say a 50 foot tower with LMR 400 no longer than 75 to 100 feet?
4. Are you near a Cell Tower, FM Radio, Paging, or other 2way Radio Tower?
Answer all these questions and we can better help you.
Look in the Database at the radio maps for coverage like this.
nvanw27
WSDU482
Kingsley, MI
The Manton site shows one or two bars, and DAT will appear. This is the site furthest from me that I am trying to receive, but it's also the only tower I can pick up that carries a few of the Talkgroups I'd like to monitor. The closer site, South Boardman, does not indicate signal strength and my scanner does not stay on it since it does not see any traffic from it. I'm able to pick up the much further Rapid City (which I am outside the radius of) with full signal strength.
1. I am 14.8 miles away from the Manton site. There is a somewhat sizeable hill between that site and my location, but that tower is on top of said hill. There's also a river, otherwise everything is just wooded land.
I'm 7.58 miles away from the South Boardman site. It's pretty much a straight shot from that site to my location - in the winter, I can actually see the lights on the tower at night. It's flat wooded land between there and my location.
3. I hadn't considered doing that, but I'm in such an area where it would be possible.
4. No. There are no cell/radio/FM towers within close range to my location. The closest cell towers are about 3-4 miles away, and the closest 2-way radio tower is the repeater at work, 5 miles away.
I have checked the coverage maps. I am well within the coverage radii for both South Boardman and Manton.
buddrousa
Ok so 4. You can see the tower but get no signal there are 2 possible causes. 1. Wrong Control Channel Information. 2. Simulcast Distortion.
Ok so 1. 15 miles the tower is on the hill. 1. The antenna may be directional looking away from you. 2. Simulcast Distortion
Can you take the same scanner and drive near the sites and it work?
smithken
Michigan
The sites the OP is concerned about are not simulcast, in fact it looks like the nearest simulcast site is 150 miles away.
wtp
Port Charlotte FL
4 (4)019 (13)MantonWexford851.425852.275852.925853.425c853.925c856.3875857.2875
4 (4)021 (15)Mesick 1Wexford851.400851.900852.400853.2875853.7125c853.900c854.9375
855.3875855.6375855.7875856.8625
4 (4)022 (16)WellstonWexford851.1375851.6875852.5625c853.200c855.0875856.5875856.6875
857.3125
4 (4)023 (17)BoonWexford851.0375851.625852.0625c852.5875c852.6375c854.5625854.8625
855.5625856.8625
4 (4)031 (1F)South BoardmanGrand Traverse851.3375851.475852.3625852.8875853.375c853.500c853.800c
855.0125856.7875
4 (4)051 (33)River CentralGrand Traverse769.78125770.08125770.53125851.725852.0375852.250852.7625
853.1375c853.350c
have you tried them all ?
nvanw27
WSDU482
Kingsley, MI
857.3125
855.5625856.8625
855.0125856.7875
853.1375c853.350c
Affirmative. Manton is one of the sites I'm having trouble with. Mesick 1 is within range, but only comes in at night. Wellston and Boon are outside of my radius, South Boardman is the line of site tower. River Central is the only one that comes in clearly.
I have all of those frequencies programmed nonetheless, but it doesn't appear to be helping.
kd8ati
Southeast MI
But if you look at my area you will not see Simulcast Listed even though I have a system that is mixed mode Analog and DMR 2 Site System.
For the MPSCS, all of the simulcast sites are listed as such. His area does not have any simulcast sites so the issues he is trying to resolve would have nothing to do with simulcast multipath issues.
buddrousa
I just listed the things that would cause the problems not knowing the area.
So this leaves a few things that I mentioned also.
1. Interference from other towers FM, PAGING or 2WAY.
2. Antenna System but OP is using Factory Antenna. Needs to install Antenna System.
3. Programming error I have ask the OP 2 times to take the scanner near the sites to see if it works NO ANSWER YET.
Ronaldski
MI DB Admin
Bay City MI
ALL simulcast is in the lower peninsula and in the southern half of that. Up your way, no simulcast.
General rule of thumb is you can get your county and depending on where your at in that county, the surrounding counties.
850's MHz is really lousy IMHO for radio use, hence why they need multiple towers and it doesnt go through walls well.
An outside antenna you could get a county(s) farther out depending on your location, tower locations and even weather will vary reception.
You can get a dedicated 800MHz antenna and those do work great, but you do lose sensitivity in the 150's and most definitely in the aircraft band. 800 - REMTRONIX 800 MHz Portable BNC Antenna | Scanner Master
Tri band, to get other frequency ranges. - BNC VHF/UHF/800 MHz REM-842B REMTRONIX Triband antenna | Scanner Master
Its just that as you go higher in frequency the distance drops. Accordingly CB/AM radio are very low frequencies so in turn you could get stations from a few states away.
nvanw27
WSDU482
Kingsley, MI
Back 1 of my questions.
If you take the scanner and drive near the other towers do you hear traffic?
On Manton, if I go across the street I can pick it up. South Boardman doesn't come in unless I'm right on top of that site.
RichM
I‘m in Northern MI as well and use an outdoor antenna. While I can pick up 3-4 towers the outlier’s don’t come in well, garbled, one sided etc. For me it is much more enjoyable to just listen to my one strong tower and leave it at that. I routinely hear 4-7 county’s off that one tower, plenty of clear sounding action with no need for the other towers, ymmv.
