Indy Fed
wirr
Senior Member
Some finds made while traveling through the Indy area:
407.8375 NAC 174?
408.0375 NAC 263, hospital???
409.1000 DMR color 1, near airport, "outbounds"
410.8000 NAC 201, encrypted
INDaviation
D1 Hater
The 317
408.0375 is VAPD Dispatch at Roudebush. They will occasionally check in on SAFE-T too, but I mostly hear Brownsburg clinic units on that TG. 407.8375 is Roudebush VA Maintenance and the db shows the NAC as 293, but it's possible they could have changed. 409.100 is most likely the USPS Airport Mail Center on Perimeter Road. That would explain the mention of "outbounds." 410.800 could be anything. I'm guessing FPS or USPS Postal Inspectors since FBI and the like are mostly VHF around here.
ecps92
Taxachusetts
Rumor was the VA Maint changed the NAC from $293 to $174 for 407.8375 due to interference a few years ago.
IF nearby maybe listen to the input to actually confirm which VA site is using this one.
$263 is the VA Police
the DMR is likely the USPS , one of their Sorting Centers - see if you can narrow down the actual site.
Some have closed the Airport Sorting/Processing and consolidated
and as others point 410.8000 is FPS aka Federal Bldg Police
407.8375 NAC 174?
cubn
Search, Listen and Submit
Marion/Johnson County, IN
I noticed TSA now carrying Motorola APX radios which made me wonder if they switched from 169.2625 P25 ENC I heard them using Jan 2021.
I searched and found a strong repeater on 407.775 P25 ENC. @milf Can you log on that frequency and see what NAC it is?
INDaviation
D1 Hater
The 317
I bet I can get that repeater from Speedway. Didn't expect IND to switch to UHF this soon. I figured only the major hubs would switch.
INDaviation
D1 Hater
The 317
They've been fully encrypted for a while now. I'll probably just run DSDplus for a while and see what I get.
cubn
I just saw that @west-pac reported hearing 407.775 NAC 482 in East Central IN.
cubn
To avoid cross posting, here's my latest findings on TSA at Indianapolis Airport:
I'm submitting these so Matt can update the database.
