TRX-1: Info on my previous posts.
RedBase1
North East England
Hi guys,
I have just noticed what is happening now , whenever i copy/paste new set freqs and send to radio (after doing all necessary checks , scanlist numbered and enabled etc.
Scanner is off during import
Tell me if this correct or am i doing something wrong ?..So lets say have #1 is filled with freqs on radio and is working and can hear pick up some traffic on channel. Now i go and look , i think ok i want to put Air freqs into #20 I do everything i did with #1 what i am doing is , do all checks so everything is setup , find freqs , copy/paste to conv tab , but i click on scanlist boxes on the ezscan page and i put/ change the boxes (black fill on copy) and (black fill on default) on #20 BEFORE i send click on Copy config to scanner/sd card.
The program then does its work .. so let it carry on....then message comes on pc screen Copy Complete. When it powers back on , i look on radio , scanlist..empty , scan sets empty. Objects empty ?????
Nothing.
Also i said before , when i do have freqs installed on radio , say #1...then i send new diff freqs of a diff type Air for example , it will install air and delete #1 etc etc.
Hope this makes sense its best way i can describe whats happening , thanks for reading.
Wackyracer
Far right column in conventional tab is where you put the scanlist number, then under the scanlist tab or general tab you must enable that scanlist number
