WS1065: INSIDE the Usb Cable for WS1065
Bugspro
I buy a WS1065 fews days a go. I Open the programming cable (Whistler). Inside is FTDI chip... and it's work with ButelArc500 and PSREDT 500 very good. I have Order in march 2020 a Original cable (04A19) with white seal (see pics) from Whistler. But I can't use this cable with ARC500 and only read and Write with PSREdit500. Also this Cable give me CYPRESS driver...not FTDI driver. The pics inside from a RadioShack 20-546 Cable, I'ts the same board then Whistler. Also i use a after marker 20-546 cable from Ebay seller. It's a real FTDI cable and it's work #1 with Arc500 and PSREdit500.
TAbirdman
MO
The image with the cable that has the white dot on it. From seeing the large insert Whistler sends with the scanners, that indicates ( as you mentioned; a different chipset) that you have to reconfigure the software to get it to download to the scanner.
Bugspro
Yes and i try many cenario and the cable won't work with Butel Arc500,and he don't find com port.
