Installing battery on G5
lsh1885
Orlando, Florida
I can't seem to get the battery contacts to meet up with the contacts inside the pager. What am I doing wrong?
qc
San Francisco Bay Area
Hi, is the Pull-tab facing you after installing the battery?
lsh1885
Orlando, Florida
Thanks I finally got it I had to remove the belt clip to get it in. Is there suppose to be three lights on when it is charging?
IAmSixNine
Dallas, TX
You have a G4 as well, swap batteries and see what happens.
Its possible the new device just has low battery and needs to charge a bit. But from my past experience they dont have all lights on when charging.
lsh1885
Orlando, Florida
I bought the Charger amplifier also it doesn't seem to matter which charger I use though. I bought it from Rays Pager Sales I called him and he said to charge it overnight and if that doesn't work he said to send it back.
lsh1885
Orlando, Florida
I sent the G5 back to Ray, he has already repaired it or he is sending me a replacement I am not sure which but it will be here on Saturday. I couldn't ask for better customer service than that.
motomeso
Ontario
Battery was likely dead. If you leave it on charge long enough the 3 lights will go away.
lsh1885
Orlando, Florida
I had on charge for over 24 hours and the battery showed no signs of life and others told me in this thread that having the three lights on the pager was not normal. Thanks for your input though.
motomeso
Ontario
No problem.
I see this all the time with three possible fixes.
Continue to charge until the lights disappear and the charging indication shows on the unit.
Battery pull.
3 finger salute / reset.
I'd be interested to know what the repair was on your unit.
