Anyone else experience significant interference across the lower VHF band? (25-54MHz is where I mostly hear it)
It's so bad some days it can sometimes bleed through the PL on certain frequencies I have programmed. I can't even quick search across the band cause it just stops on nearly every single frequency with terrible noise.
I can't find the source. Has anyone every experienced this in this band area and identified the source(s)?
Thank you!
Thank you!
