Interference on county fire
Bullmax
London, ON
I am wondering if anyone can help me with interference on a couple of frequencies I have on my feed. These are the middlesex county fire ones. 154.7250 & 150.7250. Every couple of minutes I can hear whats sounds like static and almost like a radio station. Just wondering how I can fix it. I am using a 396xt and was using the stock antenna. I switched to the home made dipole antenna and it does give me better reception but now I hear this interference.
London EMS, Fire and OPP Live Scanner Audio Feed
sirsmiley
Ontario
bad ground causing induction of the radio band? double check all your cabling and make sure the cable is properly shielded as well (quad shield rg6 or what not).
Forts
Ontario, Canada
Are you using PL tones on these channels or just carrier squelch? I find that band is bad for getting trampled on from US stuff, which is why they changed the frequency from the old 154.3700 a handful of years back. Using the PL tones should certainly help.
Bullmax
London, ON
Thanks for the replies.
Forts - Just using the basic squelch. I have no idea what you mean by PL tones. Is this a setting?
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Wow!
The Simcoe County Mutual Aid frequency is 154.3700Mhz and I hear Michigan calls on it all the time.
I can't imagine how bad it must have been down in the London area.
krokus
Southeastern Michigan
Wirelessly posted (BlackBerry8530/5.0.0.973 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
My guess would be cable TV leakage, possibly radiating from a TV or VCR.
gary123
most fire depts here use 107.2, the usa likes 136.5
Forts
Ontario, Canada
Yes, it's a per channel setting. Try this: Spin the dial and call up County Tac 1 on your 396XT. Press E then scroll down to Set Audio Type and hit E again. Scroll to Analog Only, hit E again. The next screen will already have CTCSS highlighted. E one more time. Now spin the dial until you get to 91.5Hz and hit E. Do the same for County Tac 3. Basically what this will do is the scanner will ignore any transmissions on this frequency that don't use a subaudible tone of 91.5Hz. You should find it will dramatically cut down on the noise you hear.
Most conventional repeater channels use CTCSS or DCS (same idea, different format). You can look in the database to get these tones, or the scanner has a CTCSS/DCS search mode you can use to find them yourself.
Forts
Ontario, Canada
Wow!
It was awful... I don't know how many watts St. Clair County puts out, but it would just trample everything in it's path around here.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
I think it's generally a radio shop standard.
One shop will put all it's departments on one tone while another shop will use another tone.
192.8hz used to be pretty standard in Simcoe County but over the years, almost every department uses a different tone now.
Bullmax
London, ON
Thanks Forts, seems to have done the trick.
