Hi,
I own 4 HT of Baofeng Uv-5G and I have the same problem on all of them.
About 50% of the time when trying to initiate communication the other party can't hear anything. The other HT does receive the signal (I can see the green light turns on) but no voice. I have tried removing the CTST code, using different GMRS channels and also changing the squelch to minimum.
I also verified the problem with other types (Not Baofeng) of HT that receive the signal but no voice coming through. I did notice that if I press the monitor button for few seconds on the receiving unit suddenly I can hear all communication which is expected as it ignores the CTSS codes. When I release the monitor button (CTSS codes are enabled again) the problem goes away till it comes back again sometime in the future. The "fix" also working in a scenario when no CTSS codes are set to I assume the problem is not related to the codes.
I thought I got faulty units but then I ordered another set which has the same issue.
Please advice
Please advice
