tomasG
The thread on whether or not CHP should go to trunking has sparked some excellent debate! Rather than add this in that thread I thought that a new topic was more appropriate.
Should interoperability be done at the patrol car level, at the regional dispatch center level, or both?
I actually believe that it should be done at both levels. My reasons for this are numerous, but first and foremost, officer safety. I believe especially after many spirited debates with my father who works for CHP that the patrol car radios need to be simple. Although the new breed of cop is computer savvy the new integrated system really seems to be a hauge-pauge of crap tossed together. It presents a major complexity for the officer and tecnical support nightmare. An officer should be able to operate the system with one hand while in a pitched gun battle in the middle of nowhere.
I believe that limited direct communications should be available from the patrol car and the hand-held. Instead of 700/800MHz hand-helds I believe that they should be P25 VHF trunking and that the CHP radio system should migrate to VHF. By using a trunked system talkgroups may be preconfigured at the RCC for the expressed purpose of communication with agency XYZ. The officer just changes the channel on his HT or mobile. Conventional channels like CLEMARS, NALMARS, and CALCORD would still be on the HT and mobile.
On-scene communications are done via HT and not inside the car and this is one key reason that I think that the proposed rats nest of interconnected junk in the trunk is ill-advised. When a CHP officer is on duty his primary mission is traffic enforcement and not building security. The rationale that I have read regarding CHP selecting 700/800MHz radios doesn't hold water since even Security Services Division is on UHF. The argument has been made that 800MHz radios have better building penetration and this is not entirely the case. Studies have shown that considering all factors VHF has a 20% edge over UHF and 800MHz primarily because of path loss. The occasional call to a DMV office for an arrest does not justify using 700/800MHz HT's. I have never seen a DMV office that is massive in size and to the extent that talking in and out on VHF doesn't work. Considering also that the vast majority of CHP's work is either in the three metro areas of California but far, far more in back country and roads less traveled, who is Chuck the Chippie gonna talk to? The CHP RCC needs to be built to hear Chuck and Chuck should be able to talk to XYZ just by selecting a channel. No Captain or above should be required to approve a patch as is the case in Los Angeles.
When building a communications network the given standard is a minimum is -40dBm signal strength. Most law enforcement systems are designed for HT operation by default. A 5-watt VHF HT can easily access a mountaintop repeater with ease. Hams do it daily. Should CHP go to a P25 VHF trunked system this would be accomplished with half the number of radio sites needed for an 800MHz system. Because the infrastructure would already be in place talkgroup patches to allied agencies could be accomplished without the patrol car being required as a relay. There can be many what-if's, but what if the CHP cruiser has gone over the side and the car is DOA? If all of the eggs are in one basket how then will Chuck the Chippie call for help?
This is just my take on it and I look forward to hearing yours.
