Invalid channel feature?
KJ4SKP
Hoping for a little guidance from the Harris guys. I programmed some UHF/VHF frequencies into my XG-100P which I've done successfully in the past. Today however the frequencies in the "C" bank all have an error stating "invalid channel feature". The "C" bank only has VHF frequencies in it which I'm guessing is the issue but not sure why? Any suggestions why I'm getting this error?
adamr368
NJ
Did you add wideband channels but your radio lacks the feature?
BigLebowski
Piedmont NC
RPM will let you turn on any feature that the radio is capable of regardless of whether or not the radio has those options turned on, which results in this error. Typically this shows up when you turn on wideband for one or more channels when the radio has the "Wideband Disabled" option turned on.
As a side note, it will still let you program VHF wideband in the Amateur and Marine bands even with the Wideband Disabled option.
Skypilot007
Medford, NJ
What about UHF amateur, 440-450?
KJ4SKP
My radio features say "wideband disabled". Can this feature be enabled in RPM?
