IP-223 trunking setup
codyw720
I recently got a TELEX IP-223 from one of our old NXDN trunking sites and are needing to transfer it to another location. It's setup with a NX-800 base station and a DCB encrypted tunnel. I am needing to figure out how to change the IP and settings so it can connect to another NXDN trunking site.
I hope this is enough information to get started, but the people who set this whole system up no longer work with us...
Firebuff880
Boynton Beach, FL
Just put a cross over cable in place and then open the configuration page with a browser.
You can also go in through the serial port via Telnet and reset the unit back to factory.
codyw720
Awesome! I'm able to get into it now and am looking through all of the settings. I'm trying to link a base station with the IP-223 to another base station and IP-223 at another location. Am I needing to set it up through csoft or do I just need the two units? It's going through a Kenwood NXDN trunking system.
codyw720
Is there a better option? This is some old equipment that was pulled.
Firebuff880
Boynton Beach, FL
If I understand you, I think you can set this up back-to-back, as long as it's a permanent, always up, patch. If you want control, then you should go through CSoft.
And I second the "DCB Ethernet tunnels " suggestion for tunneling things.
codyw720
It's going to be a permanent thing. We don't want to have to build a whole repeater system in the new building since it's right down the street. We had this IP-223 setup for another site but that one closed down and they kept the equipment.
I just need to program the 2 base stations with an IP-223 each and talk to each other. My understanding is that on one side, it's a conventional portable talking to the base station. That then takes it from the IP-223 to the one that it is linked to at another location and broadcasts it to a specific channel that the receiving base station is setup for on the trunking network.
This is the only Telex or Motorola equipment we have really ever deployed into the field so it's a bit of a new world for me. Currently, I am going to look into the DCB tunnel tomorrow and see if that makes a bit more sense with linking the two. Is that a good place to start?
