Is the database wrong?
wb2qqj
I've loaded the data for Woodland Park and Little Falls, Passaic County, NJ and there is no decoding. Is the data for Passaic County NCIS trunking wrong? (They are not listed as encrypted.)
Or, do I need to enter something different.
It would help if you included a link to the RR database where the system is located.
Whiskey3JMC
Simulcastylvania, TE
What make & model scanner(s) are you using to bring them in? Looks like Woodland Park Police and all Little Falls services have talkgroups on NJICS (no encryption notated) so, could be a number of things as to why you can't bring them in.
Might be worth checking the analog frequencies listed below as well
Welcome to the forums!
K2NEC
5F6
I'm hearing them loud and clear and not encrypted, check your settings
wb2qqj
Thank you everyone. I'm using SDRTrunk software on a computer. I was setting it myself, then thinking I was missing something I utilized RadiorReference to do the set-up. Should I only track one control channel and/or reduce my antenna and RF gain?
slingshot202
Dazed and Confused
New Jersey
I get them on the West Orange Simulcast system. It will depend what systems they are broadcasted on.
dave3825
Suffolk County NY
Post a screenshot of your programming, your tuner settings and the spectrum receiving the cc.
slingshot202
Dazed and Confused
New Jersey
If you stop the scanner on a channel you want to listen to on that system, are you getting Control Channel Lock or is it searching?
wb2qqj
Thank you everyone for all the help. I got it working, but poorly. I've come to the conclusion that the computer just isn't fast enough to do the job. I bit the bullet and got an sds200. Now I'm trying to figure out how to optimize it so I can scan the trunking and the old fm frequencies fast enough to catch them all. The trunks take a lot of scanning time. I'm considering cutting out the non-control fresh.
Again, thank you all so much!!!
ecps92
Taxachusetts
I doubt it is the speed of a computer, if it is receiving but poorly that is either
a. Poor Antenna
b. Simulcasting issue with the existing radio/antenna set-up
I would experiment more with your existing antenna and orientation first
Sometimes with Simulcasting less of an antenna is better (paperclips have been known to work)
dave3825
Suffolk County NY
I would post pics of the programming and pics of the settings.
I was running multiple sdr programs on a pc that had very limited resources
