Is there a way...
216DawgPound
Cleveland, Ohio
Is there a way that when a person goes to a regional database page (county, parish, etc...) That a larger trunked system can show the region in question when a person goes to that region page?
An examp!e: Ohio MARCS-IP system is heavily used in lots of areas throughout Ohio. So, if a person goes to say the Geauga County page and selects Ohio MARCS-IP it goes right to the Geauga County portion of the database entry for Ohio MARCS-IP instead of having to scroll through everything else?
I know that's probably a bad example. But, its a thought.
wa8pyr
Staff member
Lead Database Admin
Ohio
It’s not possible at this time. Best bet right now is, once you’re on the MARCS page, use the CTRL+F feature on your browser and type in Geauga.
wtp
Port Charlotte FL
also you can go to the marcs page (or any) and click on the county header at the top and the counties will be put in alphabetical order.
you might find some counties are listed more than once.
and yes, the control F thing will help in that case also.
wa8pyr
Staff member
Lead Database Admin
Ohio
Counties should already be in alphabetical order, with the municipalities and other groups (if necessary) listed below the main county category.
Whiskey3JMC
Surfer of the Delaware Valley Airwaves
Simulcastylvania, TE
ctrl if doesn't work when using a tablet. LOL. But, I get what you're saying
You can use the filter sites option and tick off only the county(ies) you want to appear. Doesn't appear to be browser-cached however, if you navigate away from the page or refresh it your selections are lost
