Is There An Easy To Install Plug & Play SDR?
haleve
Pompano FL & Melville NY
I'm thinking of taking the SDR plunge & have spent the last week combing through the exhaustively massive FunCube, AirSpy, Blade, RTL, Dongle, etc stand alone units, boxes, cards, USB sticks & related software files, forums, blogs, YouTube videos & Wiki's until my head is ready to explode, I just want a simple to install plug & play type SDR for my desktop PC that primarily covers 5 MHZ to 108 MHz or even just 20 MHz to 55 MHz without all the zip file, downloading, tweaking & calibrating that seems to get everybody in a tizzy, anything out there for us noobies to cut our teeth into this aspect of the hobby with?
Thanks for your time & everybody please have a happy & safe holiday.
Voyager
I know the Zaddig drivers with the SDR# program are pretty plug-n-play, but most any driver/software needs downloaded and installed. Download each, unzip, run, and play.
If you don't like tweaking, you likely won't be happy with any SDR.
Flatliner
UK
The best SDR to fit what you've asked, is the Funcube Dongle Pro +. No need to manually install the driver, as it automatically installs as an audio card.
http://www.funcubedongle.com/?page_id=1113
If you want it *really* easy, without drivers,zadig,etc, wait for RFSpace CloudSDR ;-)
Range 0-1500MHz or "mini version" 0-56MHz.
Plug it in to your network, download client software and reach it from anywhere, any device, any OS.
73
Paul
PD0PSB
KC1UA
Scan New England Janitor/Maintenance
This is a spot on comment though, and something to strongly consider before you take the plunge. You are going to be doing a lot of tweaking to obtain your peak performance.
With that in mind, why not cut your teeth on one of the el-cheapo RTL dongles? It'll cover most of what you're looking for and give you some experience before you try to move to something more robust. I'd rather spend $20 to find out something's not my niche than $200 or more.
Just sayin'! :D
haleve
Best Entry Level RTL Dongle
Just sayin'! :D
Works for me, what would you recommend?
AZScanner
Somewhere in this room. Right now, you're very col
Here's the most basic model: NooElec - NooElec NESDR Mini SDR & DVB-T USB Stick (RTL2832 + R820T) w/ Antenna and Remote Control - SDR Receivers - Software Defined Radio
However I found out that these things need constant fiddling to stay "on target". I'm constantly adjusting the PPM value as the dongle heats up or cools down.
For 50 bucks more, this one should be a lot more stable and give you a better experience: NooElec - NooElec NESDR Mini+ 0.5PPM TCXO USB RTL-SDR Receiver (RTL2832 + R820T) w/ Antenna and Remote Control - SDR Receivers - Software Defined Radio
Of course once you realize how much fun this is, you'll want to go out and get a "real" SDR like the Airspy, HackRF or USRP. ;) These darn hobbies, I need to find one that pays ME lol....
-AZ
Token
This might be true at the entry level or with out of main stream devices, but it is certainly not true for all SDRs. Many are no more difficult to install than a printer. Run the installer, plug in the hardware, use the hardware. Of course the learning curve of what an SDR can do after it is functioning is a different story, but no more so than a first time user looking at a hardware HF radio and wondering what to do with the “Twin PBT” controls or what the “ANF” button does.
The RTL SDRs are a mixed bag, sometimes they are easy to install, run the Zaddig and select the device (most of my installs have been that easy), other times they take some real effort. The number of requests for help on this board just to get them working is a pretty basic indicator that they can be a problem. Of course, what you don’t see, because they are busy using the radios, is all the people who install them and they work with no problem at all.
RFSpace devices, like the SDR-IQ, NetSDR, SDR-14, and the upcoming CloudSDR Paul mentioned, install SpectraVue, run the software. You do have to tell the software which model you have installed but still typically no tweaking, just click the device on the list, a one-time operation that you never have to worry about again. And unlike some of the RTL installs, there is never any doubt about the name / model to choose. The Ethernet RFSpace models have the added step of having to click the “find” button, and if your network is hosed (not the SDR or the SDR software’s fault) you might have to deal with your network. If you want to put the devices online to use remotely typically more tweaking is required, but to put one of my spare SDR-IQs on SDRAnywhere three days ago, so that now anyone can use it online, took 4 mouse clicks, and entering the name I wanted to call the device, after downloading the Zip.
WinRadio devices. Really plug and play. Run the installer for the program, it recognizes and installs drivers as needed. Done. Run the GUI, use the radio.
Perseus SDR. Run the installer for the application. It typically installs all drivers as needed. Done. Run the GUI, use the radio.
Elad FDM-S2. Run the installer, it installs everything needed. Done. That one is a bit more “tweaky” to actually use after install, as some basic operations are not very intuitively placed (display and DDC bandwidth in menus instead of buttons, for example). Plus it is a busy interface, so finding how to do things can be frustrating for very new users. But basic use, install and run the GUI.
T!
majoco
Stirrer
New Zealand
+1
G33DDC goes up to 50MHz but there's not a lot of useful activity above 30MHz - even if you call 11m useful!
Happy Christmas to all our readers!
haleve
And I Thought Trunking Scanners Were Lethal!!!!
For every good post about every USB style SDR there has to be at least 100 negative post, I guess with every new technology comes those ever present growing pains, anyway I guess I'll cut my teeth on the FUNcube Dongle Pro+ since it appears to be the most affordable & easiest to get up & running, thanks all & Happy New Year.
The New FUNcube Dongle Pro+ | FUNcube Dongle
haleve
Sorry to bump up this rather archaic thread but I just realized the FunCube Pro+ doesn't cover milair so I've been looking at the NooElect NESDR Mini 2 dongle since it covers 25 MHz to like 1700 MHz, anybody familiar with this, I've read mixed reviews on other websites, I feel I'll be way behind the learning curve since this stick doesn't have the drivers already installed like the Pro+, thanks in advance.
Voyager
I have a couple of those and severla of the original minis. I barely notice any difference between them. But, as you are dealing with weak signals, you might want to consider an AirSpy if it's in the budget (and it should be if the FCDPP was).
The advantage of the AS is the nearly 10 MHz bandwidth as opposed to 2.4 or so. For the Milair band, that means you can scan the whole thing in about 15 swipes rather than about 50. You also get much better dynamic range.
Even if the FCDPP covered MilAir, the 192 kHz BW would mean it would take about 800 swipes to see the milair band.
haleve
So Many Sticks
I was originally looking at the AIRSPY before I found out about drivers that the FunCube Pro+ had already installed, I also heard that to follow trunked systems you need two sticks per PC so I need 4 sticks for my 2 PC's & I was hoping I could get jparks29 setup running with the paired sticks to overcome the inherent RF leakage problems, so needing 4 sticks precludes midrange SDR's like the AirSpy, FCPro+, HackRF, Blade etc for now unless a single SDR comes down the pike that can handle trunking, I was hoping to get this project up & running before I headed back to Long Island for the next couple of month's, It's 0239 hrs & I'm still stuck here thanks to the snowstorm, I'm completely wiped & I need some serious sleep, later.
Voyager
Can you translate that into English?
Yes, you need 2 dongles for trunking. Maybe get a variety of dongles since you need 4, and you can evaluate which work best for you.
