scannermanner1
is there a better performing Wilson phone booster antenna then the 12 inch 800/1900 antenna??
I was thinking of 1900 mhz quarter wave antenna maybe?
Lots of choices, depending on exactly what you need.
I have a Wilson amp left over a work that we used to try and address an emergency call box not being able to connect. The antenna it came with was pretty junky. I installed an NMO on top of the call box and put up a better antenna.
Not sure what your mount is, but I'd suggest NMO, as it opens up a lot of options.
I've used these:
https://www.tessco.com/products/displayProductInfo.do?sku=423940 This one worked surprisingly well. Low profile "blade" type antenna. Worked great for AT&T service.
https://www.tessco.com/products/displayProductInfo.do?sku=458545
This guy works OK. Not totally impressed with the build quality, but it has worked well.
https://www.tessco.com/products/displayProductInfo.do?sku=495864
This one works OK. Wilson brand. I wasn't expecting much, in fact I ordered 2 so I'd have a back up. The original has been on top of a call box for 5 or 6 years now without issue.
Hello.
Wilson is consumer, but it does work.
The problem is that the losses are large at 900 MHz but HUGE at 1900 MHz!
You would need some really quality coax for anything over a few inches!
Figure on $20 a foot for the really good stuff.
Next, what kind of connectors are you planning on, kind of hard to put an N connector on a cellphone.
Remember, 1900 MHz is in the microwave band.
I can envision a waveguide mounted and terminator to monopole on each end mounted in a pickup.
I am sure someone has tried!
Yeah….
I was using double shield RG-58 without issue.
$20/ft, seriously?
I was using a Wilson iPhone docking station. It had an SMA on the bottom of it, totally suitable for 1900MHz and above.
The little Wilson adapter worked quite well. There was a specific place I'd go camping where the iPhone would not be able to connect to AT&T's network. Putting in the phone in the cradle solved that.
Just remember, there has to be -some- signal there for it to work with. Also, make sure that the antenna cannot "see" the docking cradle (if that is what you are using). If the passively coupled units are too close to the antennas, they'll self oscillate and shut down to prevent hosing up the cell site.
Hello.
I'm using a 'wireless' 800/1900MHz BDA with a Smoothtalker passive coupling cradle, RG-174 from cradle to BDA, and RG-58 from BDA to hole mounted NMO 800/1900MHz antenna... Works just fine... As you stated you do need some signal for it to function, although with the range limitations of HSPA, I have found instances where a really high gain antenna is actually a hindrance to the setup.
Either way, no need for coax that is $20/ft, or N connectors or wave guide :weed: WTF?
Sent from my iPad using Tapatalk
thank you for the information!! I am using RG 174 from the antenna to the amp and then from the amp to a little patch thing put by your phone
it seems like the RG 174 has been working fine, when I install the amp for real in my car then I will change the rg174 to RG 58 and get a NMO antenna and call it good
Just remember to get a decent dualband antenna. As I stated before, any of the three mmckenna linked in this thread will work just fine. But do remember that you need adequate isolation between the patch antenna inside and the external antenna. Also do buy a BDA that can sense when it starts to oscillate otherwise you will create harmful interference.
Good luck!
what exactly is a BDA??
I know that the booster I have the lights on it will go red if both the antennas get too close together to prevent oscillating like mmckenna was pointing out
Is all this in an effort to improve your cellular service? If so, it might be a lot easier, more effective, and possibly less costly to switch carriers.
That shoots that idea. I was going to suggest Verizon, as I've found them to have the best coverage anywhere I travel. I live in Michigan, and travel mostly North to the upper peninsula of Michigan, and South, to Florida. My wife travels East to Rhode Island, and has been to Vegas a few times.
Where are you located?
