is there away
kamikaze1
greenwood sc
is there a way to use my usb program cable to make it input audio from scanner to computer
i have broadwave but need to know how to connect it to pc i have a delta 1010 audio card and could do it that way but ill need a jack for it
leeme know
ST-Bob
Worcester, MA, USA
No, the USB programming cable cannot be used to feed audio to the computer. This question should be in the Live Audio Administration topic but here goes:
You need to take the audio output from your scanner (usually either a 3.5mm mono or 2.5mm mono jack) and feed it into the line-in of your audio card. This is done with appropriate audio cables available from any Radio Shack or similar. You may need to use a stereo to mono cable or adapter since most scanners are monaural and most sound cards have stereo line-in jacks. It depends on what scanner you have and what audio card.
You may want to look at the directions in the WIKI for hosting a live-audio feed. It has lots of information on hooking things up.
rdale
Lansing, MI
You also need to fix your subject line, anyone with knowledge of the issue probably passed your post right on by.
