is this a good antenna???
Laxplurr06
Boston, MA
I own the Centerfire dicone but not the Radio Shack antenna, so I cannot compare them. I like the discone. I have had results that are almost as good as the Scantenna ST-2. I have about 75' of rg-8 coax connected to it. The ST-2 has 50' of rg-6 connected to it.
Remember to get the best coax you can afford at the shortest run possible. Also height and whether or not the antenna is inside or outside will effect the performance.
Laxplurr06
Boston, MA
I would recommend that you buy the Scantenna ST-2. It works great on on all bands except higher ones like 800mhz. Its under $50 and the coax is included. The downside I would say is its height. Its 8ft tall. Also with the discone you can transmit with it.
Monster75
Jackson County, Michigan
wow it says it is the best on the market.... so is it really that good.... how can this be better then a discone.... i believe you its good just trying to learn as much as i can...
benbenrf
United Kingdom
I can assure you its no where near the best on the market for that bandwidth ... I can name you a few antenna's that will knock the socks off that Scantenna - the problem is they all cost lots more money (lots more money!).
What I think you can expect is that along side a discone alternative in the same price range, it could be demonstrated to work as well, if not even better across certain sections of the overall Rx bandwidth, and in other sections of the overall band width, you can just as easily expect to see a discone display greater gain and/or greater sensivity.
The point is, that unless an antenna manufacturer defines what they mean when claiming their product is the best, and also provide evidence to back up their claim, the statement is just another one of those very sweeping statements that manufacturers just love to make.
In the absence of performance figures & evidence e.g. x/y freq & gain graph and the sensitivity figures for different frequencies within the overall Rx band width coverage, and thats just for a start ... theres a whole bunch of other criteria that really need to be defined by a manufacturer before they can make such a claim - it ain't worth the paper it's written on. It's worth SXXXE
I'm not saying this Scantenna isn't any good - it may well indeed be a better choice than the discone option in your opening note (I couldn't say - I have no xperience with either of them - just take the manufacturers' claim (any manufacturers claim) with a pinch of salt, untill they put the evidence on the table. Ignore it completly.
The user opinion expressed by another member regards the ST2 is worth a 1000 x's more than the claim made by the manufacturer.
Laxplurr06
Boston, MA
^^^ Very Correct.
I compared these two antennas because I own both and they are in the same price range. I have heard people have had a lot of luck with with Diamond discones also. This antenna has more radials then the Center fire discone, so you should have more overall gain.
Just remember the best way to make an antenna better is to have good (Low loss) coax leading to it. The next thing would be the height above ground will effect performance. If not already put the RS antenna outside and as high up as u can, and you should notice a difference.
What coax are you using with the RS antenna you have now?
What bands do u normally listen too?
Do you plan to transmit with the new antenna?
If you answer these questions we can recommend an antenna that suits your needs.
Monster75
^^^ Very Correct.
ok i have rg6 coax cable but its only run about 20 feet in length.... i only listen to police fire and ems and air... i dont do trunking... right now at least... the coax i am using is not from RS its from walmart and its quad shielding
W2NJS
Washington DC
That cheap Amazon antenna...
1. It claims to do 40 mHz to 18 gHz. Someone must have found a new law of physics to do THAT one.
2. Radials do not affect the gain of an antenna; they only affect the impedance at the feedpoint.
3. Dig into the tech data available, learn to understand it, then make an informed decision about any antenna. If you don't do that you're just a chicken with money in his wallet waiting to be plucked by the antenna manufacturers.
If that sounds harsh, I'm sorry, but there is so much pure baloney floating around fed by uninformed opinions that sometimes it's just hard to accept it all without objecting to it. The ARRL publishes an Antenna Book that'll make anyone a pretty fair antenna expert in no time flat, and then you'll be able to separate all of the crap from the meaningful material in the specification sheets.
Laxplurr06
Boston, MA
I was wrong my bad. I will read my antenna book. I haven't got the chance.
The Center Fire discone antenna has worked well for me. W2NJS is looking at what other people have viewed for specs on that antenna. Scroll down to see more info, or visit the manufactures page. CENTERFIRE Deluxe Discone Scanner Antenna
When I asked what bands you listen too I'm talking about the frequencies the agencies around you use. VHF High/Low, UHF, 800?
CalebATC
Blairsville, Georgia
I really enjoy my ST-2 for milair, and civil air. It works and does the job perfectly. I have 100' of RG-6. Mounted at 55' above sea level. Like said above, the only negative is that you can't transmit.
Good Luck,
Caleb
