thedrizzle
- Joined
- Apr 1, 2017
- Messages
- 21
My head is swimming in radio terms I can't quite grasp. Looking to bounce my situation off of people smarter than I; thanks in advance for your time and help.
For the past year I have been running a private implementation of a SDR system that monitors Baltimore City Police & Fire system (system link: https://www.radioreference.com/apps/db/?sid=6906 ). I am just outside of the city, in NW Baltimore county, and I am in a basement apartment with only one room that faces the towers. This is to say, all the radio towers of this system are all within a 45 degree slice from where I am. I can't really discriminate which tower I point to.
On the Hardware side I have the following: Single 800mhz Yagi Anteanna -> CM3418 8-port distribution amp (with power connected) -> RTL-SDR (x 7) -> USB Hub (x 2) -> Quad-core, Intel i5 PC. On the software side I have Unitrunker v1 -> (odd numbered Virtual Audio Cables) -> DSD Fast Lane (x 6 instances) -> (even numbered VACs) -> Trunking Recorder Beta.
Over this past year, I have been learning as I go. I have a good background in computers and networking but near-zero skills in RF (but growing). I have gotten to a point where the system in running okay, but it has good days and bad days. By rotating the yagi around I get varying degrees of okay, but I have never been able to get it to 100% good. I posted here last year about how I was sure it wasn't SimuDist, and was deep in denial, but I am now to a point where I think I have looked at everything else (to varying degrees of "looked at") and I'm being receptive to chalking it up to SimuDist.
I have looked at a lot of the posts and links from this jump-off page https://wiki.radioreference.com/index.php/Simulcast_digital_distortion , so I kind of have an idea of what I am hitting, but looking for clarification/confirmation.
The biggest manifestion of pain I get is that it seems for each transmission that gets a voice VCO pointed at is has about a 30-50% chance of not locking on right. Another way to say this is a transmission entry is either really good, or really choppy. And a xmission that starts bad will stay bad the whole transmission and a good one will stay good. No call will change from good or bad mid-call. Seems almost(?) like it locks on incorrectly and can't correct mid-call.
Also, I can use Uniscope and point it to one of the odd-numbered VACs and see the eye pattern. In watching the pattern I can see the big difference between a good lock and a bad lock. Good xmissions have a very clear pattern, and the bad ones are super fuzzy to the point where you can barely make out the shape. I've looked for commonalities between the good and bad ones, and there is none. A dongle/stick that gets a crappy lock/xmission could very well have a crystal clear xmission the very next time. Sometimes on the same conversation/talkgroup. It seems like a complete dice toss every time it assigns a VCO to tune in a talkgroup.
I could write pages more (and might if someone asks a relevant question), but I'll keep the summary short at this point. I am also aware this is a topic that can generate disagreement so I will try to steer away from any questions like that.
General questions:
1 - Does this fit the profile of SimuDist? In the articles I read linked off of that wiki page, there was mention that it seems to flake out on the stronger/louder signals voices. I have noticed this. Where a lot of the chop/break-ups happen during stressed sylables. Like "P"s and "T"s can cause a momentary dropout.
2 - Is there any possible way I can 100% be sure this is SimuDist and not something else? Or is this one of those situations where it is a diagnoses made when everything else is excluded? I sooooo wish there was a log output or something that confirmed this. I do not have the radio chops to be sure it is *not* something else like gain or squelch, or environmental, etc.
3 - I started installing Ubuntu and OP25 on a test PC a few weeks ago, and got it to the point where it would see the control channel, but i couldn't get it to even try to switch to a voice channel. I then put that harddrive on a shelf and gave up because my main system was doing okay at the time. Back then, my system was running okay, with only maybe 10-20% of xmissions getting heavy choppiness. Last few days, after much antenna aiming attempts, I get about 30-40% crappy entries. (Sidenote, but its kind of funny that after trying different antenna aiming the good calls are a ton more clearer, but the bad calls are more often and worse quality; to the point where they are silent instead of super choppy.) Would OP25 be helpful and overcome these issues if they are SimuDist? Would it give me more information to help verify what is the cause?
Unitrunker question:
4 - The wiki entry above mentions changing AGC and squelch and other such settings on a scanner. However, it doesn't mention this under the section for SDR. Does anyone know if changing these setting on the VCOs would be worthwhile, or are these settings ignored for digital signals on Unitrunker?
In closing, this is frustrating me so much, and I wish I knew more than I do so that I could better describe what I am experiencing. The system I am trying to monitor is super, super busy so going to an actual hardware scanner is not really an option, since I would miss so much traffic. Me and my few users love the possibility of having an archive of the comms to reference. I'm not adverse to spending some money to get to where I want to be, but I'm just not seeing the path forward that gets me the archive ability with clear reception. I have small hopes that OP25 + Trunk Recorder will be very close to what I currently have, and might overcome the issue. Can anyone confirm that this might be worth working towards? Please help me learn to fish, not looking for someone to do it for me. This was a lot to type, please let me know if I can clear anything up. If it helps I can send privately a link to my Trunking Recorder page.
Thanks,
Dan
General questions:
Thanks,
Dan
