XTL/XTS5000 Issue powering W4 Tib without control head
Noweeks
I am ultimately looking to convert this W4 Tib to use a W3 HHCH however atm i cant even figure out how to get it to power on.
I have tried jumping 20->22
Ignition has 12v
All grounds are on the same common
I can find squat for info on the W4 Tib.
I have two radios with the same Tibs same issue on both...
What am i missing? I really hope I'm not sitting on two bricks.
All help is greatly appreciated.
Tib model HLN6883C ( dual DB-25 front )
wgbecks
NE Wisconsin
Connecting J5-20 with J5-22 on the front of the TIB should work. Check that there is A+ present on J5-20 referenced to ground.
Make note that there's an internal 5-amp fuse that may be blown if you're unable to measure A+ on J5-20 with normal power applied
to the brick.
Additionally, be sure you have Emergency on J2-15 of the 26-Pin Auxiliary Connector strapped to ground. Usually, there will be a
jumper or a strap between J2-14 and J2-15. Supply voltage on the Ignition Sense J2-25 may be required that depends upon how
the radio was last programmed.
prcguy
Here is a related question. I have a portable repeater using a pair of XTL1500s. I also have a couple of XTL2500 bricks laying around. Is it possible to have an XTL2500 power up without a head and function as a repeater receiver or transmitter on a single programmed frequency controlled through the rear connector as my current XTL1500s?
Noweeks
I am measuring -0.75v to ground from J5-20 / A+, what is the expected voltage there?
Noweeks
Update. I have found the issue and got the unit to power on. There was a power issue that was my fault.
I found that 20 J5 and 20 J6 || 22 J5 and 22 J6 are 0 ohms so jumping 20->22 on J6 ( the second DB-25 ) while plugging in the W3 head on J5 bright the device to life.
Thank you for the help and the confirmation on the jumper wires.
For anyone trying to find info on wiring a W3 head to a W4 TIB: jump 20->22 on the second ( right most ) DB-25 port and plug in the W3 head to J5 the first DB-25.
In my case the rear ACC ignition cable / pin did not affect power on.
wgbecks
NE Wisconsin
Any of the XTL models having a "W" Series TIB can be powered up to run headless y strapping J5-20 to J5-22. All else applies to normal use
of the 26-Pin Auxiliary Connector. An XTL2500 expects and M5 CH and would have to be flashed as an XTL5000 and configured for use with
a W9 CH for example before installing a "W" Series TIB.
Noweeks
I am ashamed to admit that i trusted the coloration on the wire i found and had connected the power reverse of expected polarity.
My power supply prevented operation upon short detection so luckily my brick isnt a brick.
