Issues with P25?
bretakawilly
South Lebanon, Ohio
Hey All! So I live in Warren County, Ohio and the local agencies are using a P25 system. I have a Radioshack Pro-651 and am having issues picking up anything that is trunked. I'm sure I may be missing something. The scanner does great at picking up the few conventional frequencies I have programmed. I am using the program cable I purchased with the scanner at Radioshack with the software it came with to load frequencies. I have loaded everything that radio reference shows under the trunked system for the county. I have only picked up one frequency that is digital. I did a comparison with a live feed and was missing a lot. Any help would be greatly apreciated.
n8jsw
Ohio
If you are picking up one or a few talk groups I would run it in search mode if you can and see what that gives ya
budevans
Cleveland, Ohio
Which Warren Site?
Do you have both MARCS-IP Warren P25 Sites programmed into your 651? I see that the Warren Simulcast 800 Mhz Site(s) has a large number of Talk Groups. The Warren Lebanon (Monroe) 700 Mhz Site has just 6 Talk Groups.
What also would be helpful is to know what software you used to download the Warren system(s) and configure your scanner.
teufler
ST PETERS, MISSOURI
file forf warren cty ohio
Software I use uis arc500. Here i a file for Warren cty
  • warren cty ohio.zip
budevans
Cleveland, Ohio
teufler,
I think you may have mis-read bretakawilly's post.
First: It looks like you sent files for Warren City which is near Akron (north eastern ohio). Bretakawilly lives in South Lebanon which is in Warren County (southern ohio near Dayton & Cincinnati).
Second: You sent two files, one of which is for the Uniden 996. The other (gr5) could work with the Pro-651, if that's the software bretakawilly has. Does Radio Shack bundle ARC500 with the Pro-651?
