JBC290M Magnet Mount
mike619
I was wondering is this antenna any good or not and also if used for close call scanning say in close call only mode will it help?
ladn
I didn't see any specifications on the antenna's length or design, so my opinion is based only on the photos. It looks like a magnet mount Chinesium 1/4 VHF antenna, maybe about 19"-20" long.
It will probably be fine for general scanning. It's a little too short for VHF Low Band, but will be adequate in areas of good signal strength.
Since it's designed to be mounted outside a vehicle, expect better overall performance, especially on close call, than a rubber duckie antenna used inside a vehicle.
If your primary interest is a specific band, you would do better with a gain antenna for that band on an NMO Larsen magnetic mount.
I use a 18" NMO (VHF 1/4 wave) antenna on a Larsen NMO magnetic mount on one of my vehicles connected to either a 325P2 or AT125 scanner.
dlwtrunked
Sold a lot of places. Weak point--the cable is RG-174 or similar. Every antenna I have had using that cable has eventually failed at one end (usually the ground shield breaking away from the connector).
chief21
Western NC (Summer); Tampa Bay FL (Winter)
That antenna does not appear to have an NMO base. If you might decide to change the antenna itself at some point in the future, I would strongly suggest getting an NMO base and a matching NMO antenna. NMO offers a better selection of antennas, and they are likely to be better quality as well.
Ensnared
Waco, Texas
It is a basic antenna. I had one years ago. I eventually went to NMO. I liked it for one reason, I don't know how to solder well. If I am not mistaken, it uses 58U, not 58AU coax. I prefer the former since BNC twist-on replacements work.
