JNCR Band Plan
GTR8000
NY/NJ Database Guy
BEE00
The band plan for the Fort Hamilton site was submitted earlier. I suspect all of the other sites use the same band plan, since the entire system is 380 MHz, however I'd like to verify as many as possible before applying it system-wide.
Note that the band plan tables in the RRDB are catered towards subscribers like Motorola or Harris, which use 1-16 numbering for the elements, while most software uses 0-15. So the following two elements would show up in DSD+, SDRTrunk, Unitrunker, etc. as 0 and 8, not 1 and 9.
CH ID​
Type​
Base (MHz)​
Spacing (KHz)​
Transmit Offset (MHz)​
1FDMA380.0000012.5+10
9TDMA380.0000012.5+10
AM909
Radio/computer geek
SoCal
I'm extracting the IDEN_* messages from the stuff I'm looking at now and plan on submitting them. Do you have a preferred format, like the above fields as TSV, CSV, or is just the raw DSD+ console log OK? E.g.:
Code:
IDEN_UP              ID=0 Base=851.006250 Offset=-45 Spacing=6.25 BW=12.5
IDEN_UP_VU           ID=2 Base=380.000000 Offset=+10 Spacing=6.25 BW=12.5
IDEN_UP_TDMA         ID=4 Base=380.000000 Offset=+10 Spacing=6.25 BW=12.5 Slots=2
Since I'm going to use code to extract them anyway, whatever format you want is fine, though other submitters may be more limited.
GTR8000
NY/NJ Database Guy
BEE00
That format is fine, thanks. Please remember to specify which site(s) the band plan(s) belong to, especially if they vary by site.
