Joliet School Changes
RoninJoliet
ILL
It seems Abeep has reworked the " Troy 30C School NXDN -RAN21System", I no longer hear any activity on the frequencies,...The tower that was being used is at Blk Rd and Rt59, I don't know if close call will work catching NXDN or DMR frequencies?,....Also Joliet Township West High School has gone to a DMR - DT3-XPT flashes using frequencies 461.925 and 452.20 and many talk groups showing up. I installed it as a "one freq- trunk,...These frequencies were analog with a DPL 31 which now has gone silent,...It seems the main " base" has TG 200001 and other TGs feed off of it,....
W9WSS
Retired LEO
Woodridge, DuPage County, IL USA
Ron, for what little I know about it, could it be a DMR Capacity PLUS single-channel trunked system? I am aware that all UCM Advent Health hospitals (La Grange, Hinsdale, Bolingbrook, and Glen Oaks) utilize this type of DMR system.
RoninJoliet
ILL
Thanks Will i been searching through the 451-470 frequencies and had no luck, they consist of 5 schools and are very active,…There license on the NXDN systems has one frequency changed and does not include the old control channel and i have checked each one with all modes and no luck,..Our local St. Joseph hospital also has a one frequency DMR and works great,…My grand daughter attends one of the schools and with today’s crazy world i would like to monitor it again,… I think Abeep is revamping alot of NXDN to DMR,…
belladog9651
IL
Hi Ron
Was in the area for a work project on Fri. Was able to do some logging. It seems the old freqs are still in use. I did get a few hits with the DMR as you decoded, but it is not school dist users.
461.925 D031 East HS Sec
464.525 D031 East HS Maint
464.975 D031 Joliet Busses
453.000 D031 West HS Maint
464.6375 (cs) West HS Sec
462.250 D071 Jr High Admins
461.200 Dist Unk, D015, and D141 logged. Unable to determine code, or the final end user.
RoninJoliet
ILL
Joliet west is using 461.925,452.20 on DMR, 464.975-Busses is analog as is 453.000,...464.525 is analog " Joliet Central " security, I have never heard anything on 464.6375 and I live down the street from the school,....There is no Joliet East it closed 10 years ago
