What the hell are you doing up so late young man?
......I see that I made the mistake of changing the systems over to Stationary. I'll change things back now to roaming.
That only works well if
you're roaming......maybe Statoinary should work better.
From the manual:
Your PSR-500 includes a Multi-site feature that can enhance the
operation of the scanner when monitoring Multi-site systems.
Multi-site can be enabled editing the trunking system (TSYS)
parameters for a Motorola or P25 system. Multi-site can be set to
Off, Stat(Stationary) or Roam. By default, Multi-site is set to OFF.
The ROAM setting is ideal for those times when you are driving
around in the service area of a networked trunked radio system,
as it allows the radio to find and use the best tower sites as you
move in and out of the coverage footprints of different sites. The
STAT(ionary) setting is ideal for those times when you are not
moving and are within range of more than one tower site, as it
will allow you to monitor traffic from any tower that you are within
range of.
