Jumper cable question
yankees6161
Hutchinson Ks
I will be installing my antenna out side this spring, will be using lmr400 cable. Should I use a lighter wight jumper cable to go in to the scanner or is it he 536 bnc connector strong enough to support the lmr400? If you suggest a jumper cable what cable would you use? I was thinking of something like a 4 foot jumper using 195 or 240 low loss cable
n1chu
Farmington, Connecticut
Your thinking is correct. LMR400 can put undo strain on the radio. I also use LMR400. I use a short jumper of low los cable that’s much more flexible. Just keep it as short as practical and you are good. Mine is about 2 feet long but 4 feet shouldn’t be a problem when using the low loss stuff.
That would absolutely be suitable. For that short a run, so would RG-58.
Do get correctly mating connectors, in other words, don't use adapters. If your LMR-400 has a male N connector on the radio end, make sure you get a jumper cable that has a female N connector to match it.
prcguy
RG 58/AU or better RG142 cable. Be sure to install a grounded surge protector where the LMR400 terminates inside the house.
Double shielded silver plated RG-142 is great stuff for duplexer jumpers and such but I think its overkill for a short jumper to a scanner and its pretty stiff. If the OP can get away with a 2ft jumper then a good US made RG-58 stranded center conductor should be fine at any frequency the scanner can receive.
RFI-EMI-GUY
True but while I have used both, I have had far more RG58 cables wear out at the connector from flexing.
prcguy
Not my hand made cables with US manufactured cable and thick hot glue heat shrink strain reliefs. Here are a couple of examples, an Alpha Wire RG-58 C/U and a fancy Huber+Suhner home made jumper cable.
GROL
I use marine shrink tubing for all my cable ends to prevent water ingress and provide strain relief. Marine shrink tube has hot glue inside and seals up nicely. Harbor Freight sells an assortment box of different size marine shrink tubings. I have lots of cables I made for portable operation and they last a long time. Also use self sealing silicone tape on outside junctions.
RFI-EMI-GUY
What is the trick to getting hot glue inside the shrink? Or is it some premade shrink product.
Premade.
It's usually referred to as "Marine Grade". The heat shrink is lined with the hot melt adhesive, so when you shrink the tube, the adhesive melts and flows.
Or, use an itty bitty hot glue gun…..
prcguy
Premade. My local electronics parts store has 4ft lengths in many diameters. Sometimes I'll have a cable and connector combination where the part of the connector I want the heatshrink over is much larger than the cable and the heatshrink may not shrink enough. In those cases I will cut the short length of heatshrink to span the cable and connector that's close to the connector diameter but a little smaller, then I'll use duck bill pilers to stretch the heatshrink so it fits over the connector. Now with heat it will shrink and fit both the connector and cable.
