Jumper Cables For Electrines
CanesFan95
Was Homeboys-Scanna
FL
Anyone using one of these Electrline TV splitter amps? I've got a 4-one but they're all f connectors. So where do we find jumper cables without having to jerry-rig lossy adapters? Like, I need a little 4-foot coax run that has a female F connector on one end and a male BNC on the other. Anyone know where to find this?
737mech
Clark County, NV.
If you have the 4 foot jumpers with f connectors you could cut one end and install compression BNC connectors. Lowe’s has them and the tool to use them.
Yeah, that's your best shot.
Home Depot has them also. Get some RG-6, some F connectors, BNC connectors and the compression tool. Make your own in the exact length you need. No point in paying someone else to do it when it's cheap to roll your own.
CanesFan95
Was Homeboys-Scanna
FL
Great idea, never knew about this. I meant to say F male. Can this also be done for SMAs to hook up dongles?
CanesFan95
Was Homeboys-Scanna
FL
Well, a jumper with a male F on one end and a male SMA on the other would allow for hooking up USB dongles to the Electrline with no adapters. So hopefully an SMA male can be put on RG-6?
It looks like the tools I'll need are:
Compression Tool.
Crimping Tool.
Coax Stripping Tool.
And it would be nice to find too,s that can do a lot of sizes like everything up to LMR-400.
a417
Get yourself a set of Greenlee crimpers, you can find die for almost everything you need crimped.
737mech
Clark County, NV.
What are you trying to set up? Electroline - F female out- F Male in coax--------Compress BNC Male to Scanner. If you are going to dongle and need to get to sma from here then the easy way is BNC Female to SMA Male adaptor. Like this one shown...https://www.showmecables.com/bnc-female-to-sma-male-adapter?gclid=EAIaIQobChMIwrGyjqvF7gIVbR6tBh1U6Ap1EAQYASABEgIXJPD_BwE
