These are some of the issues I am talking about if the title confuses you.
forums.radioreference.com
I had to setup my stream PC again after SSD failure and I was setting the volume for the feed when I heard a thump sitting it down on the table, I decided to tap on the case and heard it echoing back through the feed. This has happened before but I waived it off because I was not streaming just archiving. It turns out the "Microphone Boost" was set higher than +0.0 dB in the sound settings for my input device. In my case it was around 28 dB or so. Try adjusting that if this is happening for you.
Very Strange Problem
I have a radio shack pro-197 scanner that I use to broadcast my local safety forces for RR and I started to notice strange noise when listening to my live feed. After some investigation I discovered to my surprise that somehow I am broadcasting not only the scanner audio, but also the...
Radio Shack Pro-405 used for streaming is picking up ambient noise and vibration
Hi all! I have a Pro-405 that I am using to stream feeds to Radio Reference. It has been online for about nine years. I noticed the other day that the radio actually picks up ambient (room) noise if it is loud enough. Physically tapping on the scanner is easily heard on the audio feed I am...
