AngryDev
Suppose i keek my radio in a Faraday bag. I live in Post Falls, What frequency would i tune to to monitor to listen for official government instructions or information?
Thanks in advanced,
Thanks in advanced,
You are going to have much more pressing problems after an EMP, than what frequency to tune to. Problems like not having any power, and not gettting power back in the short or long term.Suppose i keek my radio in a Faraday bag. I live in Post Falls, What frequency would i tune to to monitor to listen for official government instructions or information?
Thanks in advanced,
The same frequency you monitor now for official government instructions or information.What frequency would i tune to to monitor to listen for official government instructions or information?
Its been tested extensively on a small scale and its something to worry about. And its not intended to cause human casualties.EMP has not been proven, only theoretical. Probably because anyone who would be in a position to have EMP be an issue, is dead.
I realize that - but my point is that if you're close enough that EMP is a concern, I'd be more concerned with the 1 million degree temperatures. Being prepared is good, but you also need to be realistic.Its been tested extensively on a small scale and its something to worry about. And its not intended to cause human casualties.
If the detonation is at high enough altitude (which increases the range of the EMP), the blast effects would be minimal to nonexistent. I've read that if the detonation was near the upper limits of the atmosphere and centered over Nebraska, electronic devices from coast to coast would be rendered useless. Unless, of course, you used it as a weapon.I realize that - but my point is that if you're close enough that EMP is a concern, I'd be more concerned with the 1 million degree temperatures. Being prepared is good, but you also need to be realistic.
I was just about to recommend that series of books. They are definitely worth the read.If you haven't read this....well, you should. It is damned scary, like Stephen King in his prime level scary, but for an entirely different reason, the topic of this thread.
Sure, it's a fictional account, but in a word, yikes. I expect others here may have read it as well.
An effective faraday shield to survive EMP is much more complicated than that, usually having at least one complete copper layer then a separate layer of ferrous metal with lots of low resistance contact fingers around any door opening to provide a low impedance path around or across the door. I've been in places designed specifically to survive a nuclear event like the below ground can't talk about it areas of Falcon AFB (now Schriever AFB) in CO and many Tempest shielded rooms, and have watched as they performed compliance testing. It would take a lot of $$ just in sheet metal to build to those standards then it needs to be tested for survivability. Building something without the means to test it is a waste of time and $$, how would you even know it works?One other thought on EMPs. One of my nephews has a shed on the property he bought in the Lake Tahoe Basin. He decided to put his ham shack in this shed. As he was beefing it up to handle snow load better he decided to cover the interior walls with thick sheet metal. While doing this he thought, if I do this correctly, I can make this shack a Faraday cage. He even installed a door so that there are no leaks around the frame of the door. He has some type of hookup on his antennas that shunt off the current in his coax so an EMP won't fry all of his internal electronics. I haven't been up to view what he did, but I think a visit is long overdue and I want to see how he accomplished all of this.
